Drivetrain Acceleration Vibration
Old May 21, 2008 | 09:19 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
02 R50 MC
75K miles
Lowered with H&R coilovers
Problem:
Extreme vibration during acceleration on the passeger front area, does not vibrate when coasting or between gears.
So far:
I had a lot of noise and diagnosed it as tire and bearing noise with some vibration (which I thought was due to the bearings).
I replaced the two rear tires that had inside tire wear and the tire noise went away but not the bearing noise or the vibration. I replaced all four wheel bearings and the bearing noise went away but not the vibration.
I did some more analysis on the vibration and found that the vibration disappeared whenever I was in-between gears and / or coasting. It vibrates the right front end whenever I accelerate. The harder I accelerate the more it vibrates.
My local mechanic and I are now speculating that it's the inner cv joint which will require a drive axle change out. ($500+ from MINI ) While talking to the MINI service man, he states that he has replaced 8 drive axles on 02 models in the last year . (is there a pattern here?)
The question:
Before I throw 5 C notes + installation on the next repair, did I miss anything? Could there be another cause that I have not taken into account?
Has anyone else had this issue?
Opinions and "true stories" are appreciated.
Old May 21, 2008 | 11:48 AM
fullcollapse40's Avatar
fullcollapse40
I have replaced a few right side drive axles for that exact problem with 100% success so far.
Old May 21, 2008 | 12:09 PM
zeus7625's Avatar
zeus7625
drive axle
Same vehicle?
Is it specific to the 02 model?
Care to share what it cost you for parts / labor?
THanks.
Old May 21, 2008 | 12:28 PM
MINIdave's Avatar
MINIdave
Sounds like a CV joint to me too.........
Old May 21, 2008 | 12:47 PM
daemon2's Avatar
daemon2
see the "vibration after lowering" thread
Sound familiar?
Inner CV
Old May 21, 2008 | 04:37 PM
jhiggs26's Avatar
jhiggs26
Could it be the intermediate halfshaft bearing or a motor mount?
Jeremy
Old May 21, 2008 | 05:43 PM
fullcollapse40
no, not the same car maybe 6-7 cars total.
All different years, all completely stock cars.
I dont know the price, but $500 sounds reasonable.
Old Jun 27, 2008 | 09:26 AM
Tampa MCS's Avatar
Tampa MCS
Is it always the driver or passenger side? I have read another post where a member had to change out his driver side. I am having the same issue after lowering with the H&R springs and I am trying to find the best solution. I'd rather change out the axle than the springs.
Old Jun 27, 2008 | 03:45 PM
fullcollapse40
The issue that I experienced on stock ride height vehicles is different, I believe, from the "vibration after lowering". I believe the actual failed part on these cars was the center support bearing on the right side axle. It produced a rather violent vibration on acceleration, the feeling was very close to what a BADLY bent rim feels like. You will probably find better info about the "vibration after lowering" if you search in the suspension section, more than a few others have had this issue.
Best of luck
minieater
Oct 28, 2015 02:15 PM
randeez
Oct 5, 2015 09:23 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
thadscottmoore
Sep 25, 2015 10:07 AM
gpwpat
Sep 15, 2015 11:58 AM
