Drivetrain Having the pulley mod done? Check this out.
In 07, I was on a dyno, the belt looked good, the tensioner indicated
there's more to that story with LDG but rest assured, no need to go into it here.
so, by the book, my belt is in good shape based on the holes in the tensioner?
**update**
well to confirm my suspicion I drove back to Massachusetts (going to MTTS here) and went to the gentleman who installed my Cravenspeed pulley. I had purchased an Alta V1.0 Pulley in case the pulley was the problem. We laid the pulleys side by side and you could easily see that the Cravenspeed pulley was shorter causing the belt to rub against the outer portion of the pulley. It was a mfg defect. The whole point of my post was if I had used a NAPA belt on day 1...this would have been caught on day 1. I will be contacting Cravenspeed when they open today to see what or if they will do anything for me since it was obviously a MFG defect.
update... Cravenspeed has looked at the pulley and did not find a defect with it. Kellen at Cravenspeed tried everything he could to find a problem with it but found none. As to why the Alta pulley V1.0 resolved the issue is unknown. I don't want to mess with my Mini by reinstalling the Cravenspeed pulley and diagnosing it as the mechanic who did the install is almost 400 miles away. I am sad that there was no defect found with it, as if there was a defect found I could justify all the hassle I went through.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Etrain
11
Aug 20, 2015 10:22 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
