Drivetrain Swapping from a 15% pulley to 17% pulley?
Old May 9, 2008 | 01:34 PM
  #51
Jaw_F430's Avatar
Jaw_F430
Originally Posted by rustyboy155
Not much, the higher RPM redline is really only so you can ring the motor out longer (Make it down the straight without shifting). I only made a few more HP at 8250 over 7200. With his cam you'd probably make a bit more power on the top end.
He's been mapping most of the new cars with 7600 or so. Only he can answer that though. Which car is yours? I've been at Danny's almost every day this week, seen a lot of cars .
I'm in the UK and should be getting the live map via 1320 Autos on the 15th May.
I have 1320 camshaft- is that the same one Jan has?
Old May 9, 2008 | 01:35 PM
  #52
JIMINNI's Avatar
JIMINNI
Details will come. Just wait
Originally Posted by Revolution Mini Works
BECAUSE THAT IS WHAT RMW DOES
WE POST NUMBERS .......NOT HYPE
I understand that . But if the numbers are there, then that means something made that number. Just wondering what it was .
Old May 9, 2008 | 01:40 PM
  #53
Revolution Mini Works's Avatar
it said MINI on the valve cover... does that help?
Old May 9, 2008 | 01:42 PM
  #54
Jaw_F430's Avatar
Jaw_F430
Must of said Mini Turbo
Old May 9, 2008 | 01:46 PM
  #55
No James it was stock supercharger
with the header you have on your car it won't make power much over 7200 but we can increase the rev limit past that so you can hold it down the straights.....
we have some help coming with a bigger tubed header for you that will match the ports properly
Old May 9, 2008 | 01:51 PM
  #56
Jaw_F430's Avatar
Jaw_F430
Tell me more
I think two people over here have already ordered your header and cat back will be nice to see back to back dyno to show the gain. I will wait to see how loud they are as I have put stock exhaust back on my car as the JCW catback was too loud for me above 3k
  #57
Guest's Avatar
Guest
Yes, to clarify the car represented in the posted dyno is running the stock Eaton Roots M45 blower .
Old May 9, 2008 | 01:53 PM
  #58
Guest's Avatar
Guest
Tell me more
If you think JCW is loud... the RMW one may be a tinge too noisy . JCW is actually softer than stock I though?
Old May 9, 2008 | 01:54 PM
  #59
Jaw_F430's Avatar
Jaw_F430
Very good power on the M45 @10.6 psi
Old May 9, 2008 | 01:55 PM
  #60
Jaw_F430's Avatar
Jaw_F430
Can't here my car now
Everyone has said that about the JCW but my one just seemed very loud
Old May 9, 2008 | 02:00 PM
  #61
Guest's Avatar
Guest
There's a few decent videos of the RMW exhaust. It's pretty noisy though with that header. I love it, doesn't bother me at all. Only mildly annoying when you have to have lots of power and you're trying to talk (Think hills...).
Old May 11, 2008 | 02:55 AM
  #62
NewMINI2's Avatar
NewMINI2
Hi all
Having fitted my new head (RMW) the boost pressure has dropped (expected due to big valve head, is not due to a boost leak!)and now I am thinking of upping the boost more by switching to a 17% pulley.
Just to get a collective answer does anyone see any disadvantages from switching to a 17% pulley? (or advantages apart from more power)
I initially went for the 15% as this is at the top end of the operating scale for the s/c before excessive heat is produced and it seemed the safer option as I had stock I/C (since changed to GP I/C).
James
Go with 53.5 mm pulley. That's something between 17% and 19% and works peferct. I know for at least 10 cars and all works great. Really great.
P.S I will be having Jans tune and was wondering about the extra rpm of the S/C with the 8.2k redline, will it be better to keep 15%?
Old May 11, 2008 | 05:38 PM
  #63
//MZero's Avatar
//MZero
Something like 18%
sorry...couldn't resist
Old May 13, 2008 | 03:25 AM
  #64
NewMINI2's Avatar
NewMINI2
Yes but it's hard to find it.
Old May 13, 2008 | 09:36 AM
  #65
Wake|MCS's Avatar
Wake|MCS
So, what's on the stage 1 kit? Pricing, etc.
A little OT, do you still twincharge or have you just stuck with the M45, Rotrex, and turbo-only?
Old May 13, 2008 | 09:41 AM
  #66
is this directed to me?
we can offer all of the above , custom tailored to your needs
Old May 13, 2008 | 12:20 PM
  #67
Wake|MCS's Avatar
Wake|MCS
Yea, I hadn't seen any mention of twincharging in a while so I was wondering if you had moved on to bigger and better things.
Btw, how's the stroker beast coming along?
Old May 13, 2008 | 01:11 PM
  #68
I just think there are better ways now than twincharging
we have other stages coming for the stroker
Old May 13, 2008 | 03:08 PM
  #69
Wake|MCS's Avatar
Wake|MCS
Sweet, keep the goodness coming
Old May 13, 2008 | 05:20 PM
  #70
We have laid out the plans for a 300whp supercharged pump gas setup....
Old May 13, 2008 | 05:54 PM
  #71
Guest's Avatar
Guest
Old May 13, 2008 | 06:03 PM
  #72
BlimeyCabrio's Avatar
BlimeyCabrio
I have laid out plans to lose 50 lbs.
I'm confident that your plans will yield results before mine do.
But that's not saying much...
Old May 13, 2008 | 06:14 PM
  #73
Wake|MCS's Avatar
Wake|MCS
Don't hog the popcorn.
Safe to assume you're talking about the Rotrex kit that you've been working on?
Old May 13, 2008 | 06:26 PM
  #74
nothing is safe around here
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
Mb460
Sep 14, 2015 05:50 AM
boydie
Sep 13, 2015 05:06 PM
Emnotek
Sep 11, 2015 04:16 PM
