Drivetrain rough idle
Old Apr 23, 2008 | 08:08 AM
firechris7's Avatar
firechris7
rough idle
i have a problem every once in a while my car at idleit will start running rough.. 99 % of the time it runs great its that small amout of time that it does not i bought the car used and the car did have work done to it i can tell if its a 15% or 17% pulley i have the alta cai and super sprint exhaust i installed a boost gauge and narrowed the problem down to a vacuum problem ( rough idle was the same before boost gauge was installed and has not changed) so i know it was not the boost gauge install. the gauge will read about 12 on vacuum at idle which is normal and every once in a while i will loss vacuum which the gauge goes to 0 and the car will rough idle. the car will not stale but will run rough for about 15 to 20 sec and then go back to normal. i checked the plugs and wires and they are fine. HELP ROUGH RIDER
Old Apr 23, 2008 | 03:28 PM
roggenmini's Avatar
roggenmini
I complained about a similar thing with my MINI and our local Mechanic told me to run an Injector cleaner. So I ran a bottle of Redline SI-1 through it and it seems to be a little better. Will keep running it to see if it gets better. Could be worth a shot.
Old Apr 23, 2008 | 04:41 PM
firechris7's Avatar
firechris7
ill try that it seems that when i run hess gas the problem is a little worse i have been running mobil and seems to be a little better the pump saws less then 10% enthenol wonder if this may contribute to the problem i will try the injector treatment and see if it works also wonder if with the work done on the i need to step up on the injectors
Old Apr 23, 2008 | 06:04 PM
the_red_car's Avatar
the_red_car
Same issue
Am running 15% redux, exhaust and an intake - car idles rough once in a while; 5 seconds after stopping at a light.
Switched to Shell; no issues. I've also consistently noted ~ 1 mpg improvement so price is a wash.
Old Apr 23, 2008 | 06:56 PM
Chappy's Avatar
Chappy
Originally Posted by the_red_car
Am running 15% redux, exhaust and an intake - care idles rough once in a while; 5 seconds after stopping at a light.
+1
I can tell you that when I run something OTHER than Shell, I get this problem almost every time. I also have an '04 with about 30K on the clock.
I fill up at a Valero station and my car does the same thing. When my MCS was stock, it did it, when I changed out the CAI, it did it... it's gotta be the gas.
Old Apr 23, 2008 | 08:28 PM
the_red_car
Originally Posted by Chappy
+1
Hmmm - my car has 29K. Maybe it only affects CR/W cars?
Old Apr 24, 2008 | 09:58 AM
firechris7's Avatar
firechris7
where are all the engine gurus out there that work on these engines ??? i know you guys are out there.. we need help.....
Old Apr 25, 2008 | 06:20 AM
jtack's Avatar
jtack
I get that too sometimes...my guage usually reads 14 vac at idle, but when it runs a little rough it is at 10 vac. I blip the throttle and it goes back to smooth idle and 15 vac I dont see how it could be a vacuum leak if it is fixed by either better gas or a blip of the throttle, but I could be wrong.
Old Apr 25, 2008 | 06:28 AM
Dab's Avatar
Dab
could be fuel filter... Does eveyone have higher mileage... anybody change their fuel filter?
daniel
Old Apr 25, 2008 | 06:29 AM
jtack's Avatar
jtack
36k and no fuel filter change
Old Apr 25, 2008 | 08:34 AM
totamdu's Avatar
totamdu
I had an idle problem like that twice before. first time it was a loose intercooler boot. Second time I never figured it out because I did a lot to the car that day. New gas and injector cleaner. I cleaned my air filter and checked all my boost gauge lines, I also cleaned my throttle body with a squirt of the same injector cleaner. My dad (a mechanic) recomended.
Old Apr 25, 2008 | 08:48 AM
suspencer's Avatar
suspencer
I also have a similar problem. Usually a few seconds after I crank up the car, the RPMs will dip and fluctuate for ~3-4 seconds. Then it levels out again. I don't think it's anything serious, but I would like to fix it if I new what to fix.
hmm... the_red_car's CR/W theory is looking even more probable.
Old Apr 25, 2008 | 10:51 AM
afinley's Avatar
afinley
I'm CR/W and i get the same problems. its prett infrequent, and i usually just ride it out. i pretend like i have a big cam.
Old Apr 25, 2008 | 01:29 PM
daemon2's Avatar
daemon2
My MA offered me an injection cleaning package the last time I was by the dealership. They said they have been experiencing complaints/concerns with gummed up injectors.
I declined because I had just ordered the JCW 380s and will install this weekend.
MINI seems to be aware of an injector problem.
Old Apr 25, 2008 | 02:21 PM
roggenmini's Avatar
roggenmini
Mine is DS/W so that can't be it. But it is running better after the Redline treatment.
Old Apr 25, 2008 | 06:41 PM
firechris7's Avatar
firechris7
let me know if the problem goes away after the jcw injectors install i was considering doing this i am surprised the dr obnoxis has not replied to this problem or one of the other high tech mini mechanics
if this is an ongoing problem and MINI knows about it the should be doing something about does everyone think the way i do and fix the problem no just acknowlede it...
Old Apr 25, 2008 | 06:49 PM
Guest's Avatar
Guest
Could it have a cam in it? Cars with a cam will occasionally sputter and sound rough at idle. A quick jab of the throttle usually clears it up.
I'd swap out the fuel filter as well if you haven't already.
A boost gauge won't tell you much, the vacuum will fluxuate depending on the RPM of the engine, so it doesn't mean a whole lot that it's moving around while the car is idling rough.
Old Apr 25, 2008 | 07:02 PM
firechris7's Avatar
firechris7
like i said i really dont know (about the cam) i bought the car used about 4 months ago i bought from a mercedes dealership and the guy who owned it did some major work to the car and when i bought it only had 17k miles and is an 04 exhaust (super sprint$$$$$) ,bbk, coilovers pulley reduction so on
the only thing i can think is that maybe he tracked the car dealership told me he traded this car and another car for a AMG mechanic pt on the computer and it said that some computer work was done and then 3 months before trade it it was switched back to stock at the dealer he may have had the computer flashed and the taken off before trade it at his trade it it had about 2 months left on the warranty.. and like you said a tap on the gas pedal and it goes away.... how else could you tell if there was a cam??
Old Apr 25, 2008 | 07:07 PM
Guest's Avatar
Guest
I wouldn't worry about it. Sounds like an idle lope from a cam. Like I said, swap out the fuel filter (People say they're "Lifetime" but I pulled mine at 20k miles and it was BLACK). The fuel filter is cheap, only about 30 bucks and a few hours to do yourself, or pay a mechanic an hour labor.
Old Apr 26, 2008 | 02:20 PM
firechris7's Avatar
firechris7
thanks i'll try this and see what happens...
Old Jul 12, 2009 | 06:05 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
FYI: Iv'e been told that the JCW injectors will spray same as OEM's unless your ECU is flashed by the dealer with proper mapping program to make them work to full potential......
scfiveo
Sep 27, 2019 02:27 PM
jeri534
Nov 6, 2015 01:40 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
daviday
Sep 25, 2015 01:31 AM
