Drivetrain Sound Generator
Old Apr 22, 2008 | 02:34 AM
ENGINE 58's Avatar
ENGINE 58
Sound Generator
anybody know what its does and why do we need it. the duct that connects to the fire wall keeps popping out and it raddles. i dont get any cels or anything like that . is there a way to just eliminate it. im thinking of putting a smaill filter on the end of it , kind of like a breather fliter. this thing really doesnt seem to do anything at all but raddle and i dont like raddles. any ideas or suggestions out here in nam land?
Old Apr 22, 2008 | 02:40 AM
ghosthound's Avatar
ghosthound
i dont even know where it is... i have heard of it though.
Old Apr 22, 2008 | 03:51 AM
Mutley MCS's Avatar
Mutley MCS
I can't see why you can't block it off and remove it. You just won't get that ever so slight BOV sound. The filter is not going to work though as this will leak boost, thus decreasing intake boost and power. Just blank it off with an appropriate sized plug. If you have an exposed filter such as Alta you will still have the BOV sound.
Old Apr 22, 2008 | 03:54 AM
ENGINE 58's Avatar
ENGINE 58
on the cool side boost tube there is a connection that runs behind the intake and connects to a round thing that is the sound generator. then it connects to a another square tube that runs in to the fire wall. its the part that connects to the firewall that pops out. its rectangular and there is a red strip on it.
Old Apr 22, 2008 | 05:22 AM
ENGINE 58's Avatar
ENGINE 58
can someone comfirm that you can block it off and what will it do if i block it off.
Old Apr 22, 2008 | 09:13 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
YES BLOCK IT OFF AND REMOVE IT! The plug etc. and instructions on how, are even included with our intake system for the R56.
Hope that helps!
Old Apr 22, 2008 | 09:57 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
That's interesting. I purchased my CAI kit at the Alta grand opening. It did not include a plug. So is this a rather recent addition to the kit? Do I even need it or want it.
Old Apr 22, 2008 | 02:35 PM
ENGINE 58's Avatar
ENGINE 58
i will check my instructions and see if i have a plug to block it off with. adam can we get plugs from you guys?
Old Apr 22, 2008 | 04:00 PM
ENGINE 58's Avatar
ENGINE 58
plug anybody
Old Apr 22, 2008 | 04:48 PM
FugitiveAI's Avatar
FugitiveAI
Hope that helps!
I noticed you mentioned this in another thread recently.. it seems the kit changed somewhere along the way.
To clarify on the purpose of the sound generator, does it make that supplemental whirring turbo like sound that increases in pitch and volume as you add more throttle and RPM?
And my real question is: Does removing it provide any noticeable gains in performance or efficiency?
Old Apr 24, 2008 | 06:10 AM
ENGINE 58's Avatar
ENGINE 58
the the plug is to be in the new kits just call alta and they will ship you one. i did and it will be on the way soon as they get more in.
Old Apr 29, 2008 | 05:18 AM
rippymcs's Avatar
rippymcs
Would you show us the pic once you have it installed?
Old Apr 29, 2008 | 05:29 AM
ENGINE 58's Avatar
ENGINE 58
i will try and get a before and after pic up for ya. alta called me yesterday and said i would have the plug here this week maybe even by friday. which will be great because i will be home on friday and i can put up a pic or two. you need the alta boost tubes to do this, the hole you plug is on the cold side tube that goes into the throttle body.
Old Apr 29, 2008 | 04:16 PM
FugitiveAI's Avatar
FugitiveAI
nobodies answered the big question...
why remove it?
Old Apr 29, 2008 | 06:47 PM
Konquest's Avatar
Konquest
in later model 07 and 2008 mini's the Alta CAI will prevent the duct from attaching to the firewall. Hence the provided plug for the sound generator
Old May 17, 2008 | 02:52 AM
papadimitriou's Avatar
papadimitriou
Hope that helps!
Sorry for bringing this old subject up, but since in the ALTA CAI instructions there is no mention about the sound generator and the blocking of it, can you please give me a clue about how to block this?
Thank you!
Old May 17, 2008 | 07:23 AM
ADAMSALTAMINI
Thank you!
No issue at all! The newer kits are shipped with a Sound Generator(SG) block off plug. IT allows you to remove the SG if you choose to. Some clients have noted the like the sound of the intake / engine better without the SG installed, and others have done it for addl. clearance. Either way it is optional.
Let me know if I can help further!
Old May 17, 2008 | 08:41 AM
papadimitriou
Ok, in order to remove it, I need also the ALTA hose, or just to put this plug?
Question:
Will this lead to more pressure going in the engine?
Can I find somewhere only this plug??
Will it create any problem?
Thanks again.
Old May 18, 2008 | 08:59 AM
ADAMSALTAMINI
Question:
Thanks again.
Just the plug!
No addl pressure.
No problem and you can order through us.
Let me know how I can help further!
Old May 18, 2008 | 09:10 AM
302_snake's Avatar
302_snake
BMW design
what is the design purpose of the SG? how it's supposed to work?
Just the plug!
No addl pressure.
Old May 18, 2008 | 09:27 AM
ADAMSALTAMINI
The understanding is that it is supposed to create / mask some engine noise under boost. I don't believe anyone that has eliminated the part, noticed any appreciable change in sound.
Thanks for asking!
Old May 18, 2008 | 01:50 PM
flav's Avatar
flav
my alta kit never came with the plug either, they shipped it 2 weeks later but last thing I want to do is take my CAI apart again. I am also having the same problem with the sound generator hose disconnecting from the firewall because of pressure. I'm just leaving it hanging. Does anybody here feel that will cause a problem with performance or reliability? Is it ok to leave hanging? It do notice I'm getting a rattle at takoff from it though. My other thought was to glue the hose attachment into the firewall so it doesnt come loose again.
Old May 18, 2008 | 04:00 PM
ADAMSALTAMINI
There is no pressure within the hose. But what you may want to to is remove that snorkle from the hose. Or remove the SG itself. In some cases that can get too close to the intake box and cause that interference. Let me know if I can help in either case.
Thanks again!
Old May 18, 2008 | 04:08 PM
mogollon8266's Avatar
mogollon8266
Just remove the little tube going to the firewall I did it cause of the rattle problem, no problems since
Old May 18, 2008 | 05:15 PM
ADAMSALTAMINI
Man that is what I was trying to say, but you did a much better job of it! Thanks!
