Drivetrain Survey - MCS Exhaust Types
I'm the guy that has taken over the Exhaust Guide thread started back in 2004, which is now a sticky on the 1st Gen | Modifications | Drivetrain (Cooper S) thread (This thread: https://www.northamericanmotoring.com...ad.php?t=23789)
I want to determine how to improve the Exhaust Guide. To do that, it just makes sense to me to find out the most popular exhausts out there for the MCS. (By popular, I mean the ones that are installed by the most people).
If certain manufacturers exhausts are being used way more than others, we should spend more time on those, and less on the others.
So, please take this one question survey, at SurveyMonkey.com:
(*Update SURVEY ENDED - RESULTS HERE https://www.northamericanmotoring.com...5&postcount=12*)
It asks you to pick which custom exhaust you have on your MCS - that's it, once click.
I will keep bumping this, and will put it in the general discussion listing to try and get as much info as possible. Please excuse the cross postings.
Scott Portis
Exhaust Thread Manager (by default, not by expertise)
Scott Portis
Oh, by the way, post a reply to keep this near the top if you take the survey!
Thanks - 7 surveys already in an hour, at midnight, on a Sunday night. This is one heavily used Forum!
Scott P.
Scott P.
really? they do look alot alike... does it really gain hp? cause some systems lose hp and im not sure about my system... sounds cool though!
I'm not sure if it gains much of anything. It became a restriction at around 210 or so whp so I yanked it and replaced it with a full RMW headerback.
Don't worry scott, it is in the survey as a choice. Did you fill out the survey?
As of 4/21/08, 43 Responses to Pre-2007. The leaders are:
One Ball Mod ......................... 19% (8 Responses)
Magnaflow..............................12% (5 Responses)
Alta Sporttone 2.5"..................10% (4)
OEM......................................10% (4)
Skunk 2 = Invidia, didn't see if you had Invidia, but if you do you're covered (Just put a slash or something).
http://www.surveymonkey.com/s.aspx?s...cwWQgQxg_3d_3d
Scott Portis
Scott Portis
Cool. Done deal. You know what'd be pretty sweet & sorta informative is to have a header section to go with exhaust setup. Just an idea. How do you know what the polling stats are?
Nick
