Drivetrain Oversized Crank Pulley & "Alta-nator" pulley?
Old Apr 19, 2008 | 06:13 PM
uRabbit's Avatar
uRabbit
Are these mods suggested? I have the 2.0 15% pulley by ALTA. Are the crank pulley, ALTA-nator pulley, and S/C pulley belt suggested?
Old Apr 19, 2008 | 09:44 PM
british RACING green's Avatar
you'll get lots of opinions about the crank pulley and wether or not that's suggested, look around and form your own opinion. i think the alta-nator is good for peace of mind knowing that your alternator is spinning at close to stock speed inspite of other pulley swaps
Old Apr 19, 2008 | 10:20 PM
ScottRiqui's Avatar
ScottRiqui
Well, you don't need the alternator pulley unless you also get the crank pulley - simply changing the supercharger pulley won't affect the alternator speed.
I've installed several 15% pulleys on low-mileage cars and kept the stock belt, but if you've got some miles on your car or suspect the belt is slipping, it wouldn't hurt to replace it with something a little shorter.
Old Apr 19, 2008 | 11:52 PM
uRabbit's Avatar
uRabbit
Well I've only got 19k on my '03, so not really high on the miles.
How does it feel when it starts to slip? Cause if I'm at a low RPM, and I give it a little more gas than usual driving (say, to pass someone), and take it above 3200rpm, it seems to not catch until about a second later. As in, the RPMs will jump, but the speed will not jump in complete normal unison.
edit: However, if I start off at a higher RPM, it does not happen. Especially in first gear. My "perfect launch RPM" from 0mph is around 2900rpm. I'll lose no traction, nor will I lose torque. And the "not catching" (as mentioned above) does not happen either. Just happens when I go from a low rpm to a higher rpm.
Old Apr 20, 2008 | 12:06 AM
gnatster's Avatar
gnatster
Mikes may not be high but time is. Belt will stretch over time, sounds like a good candidate to replace.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
