Drivetrain Pilo induction kit & my own short shift install..long
Old Aug 4, 2003 | 12:17 PM
momini's Avatar
momini
Just finished installing the Pilo induction system. One of the lowest priced kits and very similar to other out there. Material and fit were first rate & I would recommend the kit for this reason...not sure about gains, but I sure feel that I have better throttle response. Installation took me about 20 min.
Also did a short shift that I love. I cut out about 2.25 inches of the shift lever between the pivot point and the plastic area that secures the shift boot and ****. I used a brass pipefitting sleeve (Home Depot) to join the sections and secured them using some pins through 1/8 inch holes I drilled through the sleeve and shift lever. Total cost $2.95 and the difference is amazing. It really improves shifting and allows you to keep the stock **** fitting. Does take a little more effort to get it into reverse, as you don’t have as much leverage.
Old Aug 4, 2003 | 12:48 PM
TwOMINIs's Avatar
TwOMINIs
Do you have a before / after picture of the short shifter?
Old Aug 4, 2003 | 01:06 PM
momini's Avatar
momini
>>:smile:
Old Aug 4, 2003 | 05:33 PM
MiniPilo's Avatar
MiniPilo
Glad to hear that you like the Pilo Racing Cold Air Intake. Remember that the intake should be cleaned and oiled approx every 10k miles, about the same time as you change your oil. The cleaning kit is avaiable from www.thepilo.com
Dan
Pilo Racing
Old Aug 5, 2003 | 06:33 PM
smcfamily's Avatar
smcfamily
Hey MiniPilo - I have the Alta foam filter. Can I use your Pilo filter cleaning kit for it, or does it require something different (since it is foam)?
S
Old Aug 5, 2003 | 06:35 PM
MiniPilo's Avatar
MiniPilo
The Filter Cleaner that I have is fro Cotton Filters only. Foam Filters require a thick oil to catch the particles. I would go to alta to ask them for what to use.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
jziran
Aug 24, 2015 04:50 PM
