Drivetrain Wilwood bleeding problem
Old Apr 10, 2008 | 09:34 AM
stuttgart1's Avatar
stuttgart1
I have a Wilwood Dyna Pro calipers on the front and I have some problem on bleeding. When I open both upper bleeder valves on the calipers the fluid will not bleed from the valves instead it will come out around the bleeder valve. I checked the valve and it's clear. Also the brake paddle is very hard to push down when bleeding.The rear brake are stock and I have no problem bleeding them. The brake works fine beside it's little spongy. Does anyone have a similar problem that can share their experience. Thanks.
Old Apr 10, 2008 | 05:29 PM
nascar mini's Avatar
nascar mini
Bleeder
I have the same calipers on my 12.19 kit,you are opening the ''small'' bleeder valve in the center (1/4'' wrench size) aren't you, not the outer adapter?Because if you open the outer (i believe 7/16 wrench size) adapter the fluid will flow out around the adapter instead of the bleeder valve that is still closed on its seat.It took me a while to get all the air out,you really need a pressure bleeder to do the job properly.I have been told that its very hard to get the air out once its gets trapped in the ABS pump.Hope this helps.
Bill
Old Apr 10, 2008 | 09:53 PM
stuttgart1's Avatar
stuttgart1
OH.... I never realize there's a smaller bleeder valve... I will try again tomorrow. Bill, thanks a lot for your help....
Kimolaoha
Jul 5, 2023 01:04 PM
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
