Drivetrain Help M7 or Alta V2??
Old Apr 9, 2008 | 05:48 AM
FreeSpirit's Avatar
FreeSpirit
Hi i wish to purchase the following:
  1. IC
  2. Supercharger Pulley
  3. Crank pulley
  4. injectors
  5. oil catch can
  6. Throttle Body
But i dont know which brand i should choose can any one help??? or know of any other good tunnners.
Old Apr 9, 2008 | 05:53 AM
ECHO-313's Avatar
ECHO-313
+1 for ALTA
Old Apr 9, 2008 | 07:06 AM
polizei's Avatar
polizei
I honestly don't think it matters...I went with M7 because it was slightly cheaper than ALTA at the time of my purchase. I also like the looks of the products more, but I also have ALTA...so I have both.
-Cody
Old Apr 9, 2008 | 07:17 AM
JIMINNI's Avatar
JIMINNI
-Cody
+1, I also have both, both good companies. Question though on your list. Why the throttle body? Also if these are the only mods you have, the stock injectors are fine. Just asking .
Old Apr 9, 2008 | 07:21 AM
ScottinBend's Avatar
ScottinBend
Forget the IC as both offer very little HP for the money. Go for a cat-back, intake, pulley, injectors if you are tracking the car, and top of the list would be a custom RMW tune by Jan.
Old Apr 9, 2008 | 07:27 AM
Marwan's Avatar
Marwan
-1 for the oil can. Save your money on that!!!
Old Apr 9, 2008 | 09:04 AM
Bahamabart's Avatar
Bahamabart
It's not a must have but actually it does what it is suppose to do - w/ an OCC you will find no oil in your IC or horns. I pull about a tablespoon out every 2-3 months.
Old Apr 9, 2008 | 02:19 PM
freeskier's Avatar
freeskier
OCC is a good call, a celan IC cools so much more efficiantly.
Old Apr 9, 2008 | 02:22 PM
Guest's Avatar
Guest
Regardless of whether or not you're seeing oil blowby in your catchcan, the it still doesn't really offer any performance gain. None of these recent cars that have been mentioned that are putting down 230+ whp are running catch can's. When we're out here spending thousands chasing 5-8 HP, trust me, we'd all have catch can's if we thought it would help.
If your primary goal is to keep your IC clean, that's another story, but a catch can isn't going to give you any performance gain .
Old Apr 9, 2008 | 02:34 PM
Guest's Avatar
Guest
  1. IC
  3. Crank pulley
  4. injectors
  5. oil catch can
  6. Throttle Body
1) Intercooler - As others have said, an IC isn't necessary. I run the stock one and haven't found any reason to upgrade now with almost 90 HP over stock.
2) SC Pulley - One of the biggest bang for your buck products out there. I'd stick to a 15%, the manufacturer isn't that important. Alta, Craven, Helix, it's all the same thing really. I'd stay away from the 16% because of the odd sizing (Belt sizing can be difficult) and because people have had issues getting them on and off. Make sure you change your belt to a smaller one if you put a new pulley on.
3) Crank Pulley - Most of the "Big Guys" will tell you to stay away from this, doesn't really do anything and it has caused issues in the past with harmonic balancing. It's a pretty touchy subject on here but in my mind, after spending close to $20k on engine parts over the years, if I haven't figured out a reason to buy one, what's the point .
4) Injectors - Might be a good idea if you plan on going crazy with mods. You can get a set of 380's from Helix for around $260. These will be good up until about 210 whp. If you want to go much past that, Jan from RMW has a set of 440 cc Injectors you can get. Stay away from modified injectors without the stock spray pattern. These cause fuel puddling and you'll be throwing codes like crazy.
5) OCC - See my post above about OCC's and their merits. I don't run one, nobody that I've worked with runs one or recommends that I run one, so I haven't wasted the money. It's your call, it's not going to hurt anything, but it's really not going to help either.
6) Throttle Body - In 350+ whp applications the throttle body hasn't become a restriction, it certainly isn't going to be one on a car putting down sub 200 whp numbers. This is a MAJOR profit source for people that do them. They sell you somebody else's that they machined, then take they take yours, machine it for $35, and charge $299 to the next guy who thinks it might help. Bigger isn't ALWAYS better either, RMW has run into some issues trying to tune these.
If you're looking for a mod path for engine only, I'd do this:
SC Pulley - $99
Intake - Take your pick, they all do the same thing
RMW 440 cc Injectors - I want to say $499, but I can't remember
RMW Exhaust - ~$2000
RMW Head - ~$2200 + a few other things needed for install
RMW Tune - $350
With all that, you'll be putting down between 225 and 240 whp.
If you want to go light, pull off the 440's and replace them with 380's, and take the head and exhaust out to save $4200. With just a pulley, intake, and tune you'd probably be putting down around 190 whp. If you have the money, an exhaust with a good header would add another 8-10 HP to that figure.
Old Apr 9, 2008 | 02:48 PM
AstroBlackS's Avatar
AstroBlackS
Ditto on the IC and Throttle body. No real need for them as they don't offer much unless you are going to an extreme level of performance, in which case you would need a whole bunch of other things before you need to change those.
Old Apr 9, 2008 | 02:54 PM
Dr Obnxs's Avatar
Dr Obnxs
I'm not sure it's that big a deal
I found about a 3 C difference at red-line after cleaning....
Matt
Old Apr 9, 2008 | 04:37 PM
ScottinBend
Matt
But it does keep the crap out of the IC !
Old Apr 9, 2008 | 10:13 PM
FreeSpirit's Avatar
FreeSpirit
Bang for 3 k
I have 3k to spend on my beast!
can anyone give me a good combo with that price limit????
Old Apr 9, 2008 | 10:33 PM
OctaneGuy's Avatar
OctaneGuy
Rustyboy laid out an excellent plan. These mods have been pretty fun--total is around $3400 though...if it has to be under $3K then drop the Wilwoods and get some adjustable control arms or new lightweight wheels, etc..
Pulley $100
Alta Intake $250
Invidia Exhaust $600
Megan Coilovers $1000
Wilwood 12.2 BBKs $900
22mm rear sway bar $200
RMW Tune $350
But it depends on what you've done already. Aftermarket wheels and tires are important too.
Old Apr 9, 2008 | 11:57 PM
FreeSpirit's Avatar
FreeSpirit
Pulley $100
Alta Intake $250
RMW Tune $350
I have done version 2 alta CAI full millteck exhaust and bilstien pss9 coilovers
Old Apr 10, 2008 | 12:01 AM
Guest's Avatar
Guest
Do you just want power or are you concerned with handling and stopping too? If you just want power, get an RMW Head, a pulley, and call it a day.
If you want it all, grab a set of TSW springs, some new shocks, a nice new set of pads, a rear sway bar, pulley, and RMW Tune, and call it a day .
Old Apr 10, 2008 | 12:04 AM
FreeSpirit's Avatar
FreeSpirit
I have billstien Pss9 shocks and a full miltek exhaust already. The only problem i am in Aus and there ain many tunners here for big head convwersion. BLOODY AUSSIES!!!. so i im not sure wht to get!
Old Apr 10, 2008 | 12:14 AM
Guest's Avatar
Guest
Well, the head you can get yourself, and either install yourself or have most any shop install it that's worked on MINI's before. Do you have 3000 American or 3000 Australian dollars? Even in our weak economy I still think 3000 Aus is less right?
Old Apr 10, 2008 | 12:17 AM
FreeSpirit's Avatar
FreeSpirit
i have 3000k US yes the AUD is less
so you think a head and pulley should do it?
Old Apr 10, 2008 | 12:24 AM
D-MAN's Avatar
D-MAN
Not totally true - I have managed to line up a Dimsport tune in Sydney to go with my Thumper head. Even without the tune the baby is making some serious hp . Even though the "high performance" shop (I use that term lightly) were hopeless....but that is another story!
There are other option like piggy back systems (eg Haltech - which is made down under and there are a lot of local distributers) but I would probably stay away from them due to the nature of the stupid mini ECU!
Old Apr 10, 2008 | 12:26 AM
FreeSpirit's Avatar
FreeSpirit
Were did you get your head from??
Old Apr 10, 2008 | 12:33 AM
Guest's Avatar
Guest
Thumper, another manufacturer here that makes heads out of FL. His products are great, but it's not a true "Big Valve" head. They're cheaper, but you're not going to make as much power.
And to answer your question, yes, I think you'll be more than happy with a head and pulley . Jan is doing remote tunes now, so that could be the way to go if you can squeeze a little more dough and get a custom dyno tune.
Old Apr 10, 2008 | 12:34 AM
Guest's Avatar
Guest
Yea, you're going to run into issues if you go with a piggy back system. Stick with flash tunes unless you have the coin to go standalone .
Old Apr 10, 2008 | 12:36 AM
FreeSpirit's Avatar
FreeSpirit
yeh i tyhink i might go with the head a pulley. im thinking 17% Alta Pulley wht you think???
i want the RMW jesus head aswell just have to get some pricing for it!
