Drivetrain What's My Next Mod Would Be? Opened For Suggestions
Old Apr 7, 2008 | 03:52 PM
  #26
jaynicholson's Avatar
jaynicholson
You can get the plugs for under $9 each...
http://www.sparkplugs.com/
Old Apr 7, 2008 | 04:56 PM
  #27
etalj's Avatar
etalj
Originally Posted by Marwan
+1. But I have M7 brace, would the strut tower bolts support camber plates+M7 plates?
I think the bolts come with the camber plates. Mine did (I have noltec camber plates).
Camber plates and 19mm swaybar will make the car handle like it should If you run more neg camber at the front, you don't need the swaybar to be as big. (19mm on middle would probably be a good start, with -1.5 to -2 deg of camber at the front, and -1 or so at the rear)
Old Apr 7, 2008 | 11:24 PM
  #28
Marwan's Avatar
Marwan
Originally Posted by rustyboy155
There's currently an issue with the tunes on automatics and reprogramming shift logic IIRC. A fix is in the works .
Yup, I've got little info about that and I'm foloowing up with Jan about it. The problem is that the redline is coded in the TCU (Transmission Control Unit) and not the ECU which is mastered by Jan already. Another thing is, there's some kind of protection system that kicks in to limit the revs of the engine in case the gearbox did not shift, or something like that. Those information are from a friend of mine who works in Mini plant, Oxford.
Old Apr 7, 2008 | 11:30 PM
  #29
Marwan's Avatar
Marwan
Now I'm lost, with current engine power which is above 200HP, shall I move to suspension and brake mod? Or shall I continue slight engine mods like the RMW cam and RMW programimg?
Old Apr 7, 2008 | 11:32 PM
  #30
Marwan's Avatar
Marwan
Is there any LSD or gearbox upgrades for the automatics? I started feeling that there will come levels that the gearbox will not be able to match and tolerate the engine power.
Old Apr 8, 2008 | 10:34 AM
  #31
Some Guy's Avatar
Some Guy
I think that the auto has been taken up to at least 230HP so at 200hp I wouldnt worry. That said, aside from a tune the only other big gains to be had are either through twincharging or a new head, both of which are big money. If I were in your posistion I would get a tune then focus on suspension and brakes.
There are some really high price:performance ratio suspension components out there if you havent actually done any suspension mods yet. The price:performance ratio on engine parts starts to go down real fast once you do the big four (intake, tune, pulley, exhaust).
Old Apr 8, 2008 | 01:44 PM
  #32
Marwan's Avatar
Marwan
I really respect your opinion and like it. Now, I'm working on upgrading my rear and front brakes. I'm getting Carbo Tech ceramics on JCW calipers as well as upgrading the rotors. Next step will be GP wheels with non run flat tires, then start on the suspension. This is like for the coming 2 to 4 months plan.
Old Apr 8, 2008 | 02:32 PM
  #33
Luys's Avatar
Luys
Marwan can you order from Jeddah BMW dealer GP intercooler ?
Old Apr 8, 2008 | 02:38 PM
  #34
Marwan's Avatar
Marwan
Nope, I've checked already. Luys, I can get you one for $900+shipping. Shipping is from UK to Turkey. Tell me if you want one so I'll arrange for 2 for both of us.
Old Apr 8, 2008 | 03:22 PM
  #35
Luys's Avatar
Luys
900 box isn't expensive or normal ?
Old Apr 8, 2008 | 04:13 PM
  #36
Marwan's Avatar
Marwan
A guy on ebay used to sell them for $600. Mine are directly from Mini plant, Oxford, UK. Sterling Pound rates are going high!!
Old Apr 8, 2008 | 04:47 PM
  #37
Marwan's Avatar
Marwan
Luys, I forgot to tell you. the $900 include the following parts, not only the intercooler:
Intercooler 1 17-51-7-565-302
Cover 1 17-51-7-565-345
Air Duct (underhood) 1 51-13-4-404-668
Support 2 17-51-7-511-947
Hex Bolts 4 07-13-0-782-486
Old Apr 8, 2008 | 05:09 PM
  #38
Guest's Avatar
Guest
That's up to you, it depends on what your goal with the car is. 200 whp isn't enough for me .
Old Apr 8, 2008 | 05:12 PM
  #39
Marwan's Avatar
Marwan
Nick, power is nothing without control! Right?
Old Apr 8, 2008 | 05:13 PM
  #40
Guest's Avatar
Guest
There WILL come a point when the transmission just won't be able to handle it anymore, what that point is I couldn't tell you. There haven't been many Automatic's that have been taken up to the level you're looking to take your car.
I'm not aware of anything you could do to "Beef up" the transmission. I don't know of any LSD's (Which wouldn't help with strengthening transmission internals) for the Auto, or any other types of upgrades. The torque converter is the likely thing to watch, but since our cars, even modded, don't make that much torque, you shouldn't have any immediate issues.
You could of course sell your car for one that's stick, that will raise both the fun factor and solve any potential transmission issues .
Old Apr 8, 2008 | 05:15 PM
  #41
Guest's Avatar
Guest
This is true, if you haven't already invested in a suspension and tires to put that power down i'd suggest you do that. I've already spent all the money that needs to get spent on suspension, brakes, tires, etc. Now my focus is power!
I'd suggest a good, sticky set of tires and a stiff suspension to limit the inherent weight transfer to the rear on hard acceleration. TSW makes a great set of springs that don't lower the car that much, or if you've got the coin, go with a set of coilovers.
Old Apr 8, 2008 | 05:17 PM
  #42
Guest's Avatar
Guest
Whats the price shipped to SoCal? I know a few people that might want one .
Old Apr 8, 2008 | 05:19 PM
  #43
Marwan's Avatar
Marwan
Ok, my plan is GP wheels and have Michelan tires on them, maybe wider than the stock GP tires are, 255 or 265. Then JCW suspension and 25mm rear sway bar. This is after I finish my JCW brake upgrade project which I already started searching for.
Old Apr 8, 2008 | 05:23 PM
  #44
Guest's Avatar
Guest
I wouldn't do GP Wheels unless your only motivation is looks. They're not THAT heavy, but for the same money you could get a REALLY light set of wheels that would look great. Also, 255 width tires?!? Are you rolling your fenders? I was rubbing with 225's, there's no WAY you're going to get 255 or 265 width tires to fit under there. Especially with 18's .
Honestly that's WAY too much tire for a car this light. 215 width tires are plenty for the street and even the track.
Old Apr 8, 2008 | 05:28 PM
  #45
Marwan's Avatar
Marwan
Nick, PM sent. I must have made a mistake. I thought the stock tire width is 245. I should get back to one of the GP pictures I've got.
I NEED GP wheels because my vendor will drop any warranty on anything related to wheels if wheels are not OEM. This is why I'm paying $350 per GP wheel. Also, no one can argue that GP wheels are the best looking wheels ever on a Mini
Old Apr 8, 2008 | 05:32 PM
  #46
Guest's Avatar
Guest
Well, some people could argue that, I like a lot of wheels on the MINI. I happen to think the GP wheels are pretty nice, but I'd never use them for the reasons you stated, they're too expensive, and 18 lbs a wheel (While light for an OEM 18" wheel) is too much for me.
You're saying that your dealership in Jeddah will not honor the warranty if you have aftermarket wheels? That sucks, in the US we have a law that was passed to prevent treatment like that, I'm not sure of the local laws there, but perhaps there is something similar?
Edit: On reading further, you said drop the warranty on anything relating to wheels, does that mean anything on the axel? Brakes, suspension, axels, wheel bearings, etc?
Old Apr 8, 2008 | 05:36 PM
  #47
Marwan's Avatar
Marwan
Nope! Here things are different. On my first maintenance visit they warned me of getting ANY aftermarket part as it will voide the warranty of connected/related parts. In Saudi, Mini/BMW are monopulated by one dealer. As per the dealer, any accessory or added part should carry the warranty when:
-Proof it's OEM provided on warranty claim.
-Proof it's purchased from a certified dealer provided on warranty claim.
-Proof it's installed by a certified dealer provided on warranty claim.
I had my JCW gear shifting indicator failed once, and they asked me for the above to get it replaced on warranty!!!!
Old Apr 8, 2008 | 05:41 PM
  #48
Guest's Avatar
Guest
Wow, that's pretty harsh. I'd be careful then modding things unless you have the money to fix parts that fail! .
Old Apr 8, 2008 | 05:45 PM
  #49
Marwan's Avatar
Marwan
Yeah you are right. The only aftermarket thing I have is the pulley which I do not expect them to notice during regular maintenance visits. That's why I like Jan's tunes and work. His cars' looks are silent and never tell they are modified.
Old Apr 8, 2008 | 05:52 PM
  #50
Guest's Avatar
Guest
Yup, one of the common trends! "This car looks stock!" "Yup, well it isn't! "
sevin
May 2, 2026 06:11 AM
matthewbrakeii
May 13, 2021 08:39 AM
3MCS1DJ
Aug 23, 2015 02:08 PM
PSIChocolate
Aug 13, 2015 12:46 PM
