Drivetrain Seattle RMW tune. June 20th & 21st at Axiom Motorsports!
Yes its true, Jan is coming to Seattle for ECU tuning. He will be able to start tuning possibly thursday night the 19th (depending on the number of cars) and has confirmed the 20th and the 21st. So mark your calendar!
Here is the link to Axiom where you will find the address and a map of the area-
http://www.axiommotorsports.com/
RMW Tune: $350
Axiom motorsports dyno fee: $90 per hour or $810 per day.
Fun: priceless!
Jan recommends the Following
1. over half the hole showing in the tensioner
2. new plugs , if running more than 17% use NGK -7s or 8s
3. 91 octane gas, Chevron is usually the best
4. make sure your boots on intercooler are not worn/torn/old
5. Make sure you have no check engine lights
6. make sure your exhaust is NOT leaking
7. clean air filter
8. enough oil and coolant
9. non slipping clutch
10. 380cc injectors if 19% or 15/3% or 15/2 or 17/2 etc
if you plan on running your car on the track it's always better to have 380cc injectors over the stockers
RMW Tune: $350
Fun: priceless!
7. clean air filter
vulkandino
Oct 31, 2015 08:29 PM
NorthWestEuro
Oct 21, 2015 08:11 PM
vetsvette
Oct 20, 2015 07:42 AM
