Drivetrain What should my boost read at different speeds/idle?
Old Apr 1, 2008 | 03:04 PM
MiniJayhawk's Avatar
MiniJayhawk
I just installed a boost gauge and was wondering if my gauge is reading correctly. When at idle at a stop light it is reading about -10 on the vac scale. Should it be 0 at idle? It drops to a dead even -20 vac when I let off the throttle. It gets up to about 13-14psi on full boost. Does all of that sound right, or do I have a problem? My biggest thing is why it doesn't sit at 0 when idling. Is it actually in vac mode at idle and low throttle situations?
Thanks!
Old Apr 1, 2008 | 04:16 PM
sailorliz23's Avatar
sailorliz23
you dont get 0 at idle because your car is in vac. you wont get 0 unless you are accelarating without giving it any real gas(by this i mean pushing the pedal down all the way). i have a boost gauge i installed and it reads the same way so dont worry. my boost reads a little higher when i have my ecu on but i had to send it back :( to get a new harness.
Old Apr 1, 2008 | 07:41 PM
thlaxx's Avatar
thlaxx
same here. no worries just in vac. What have you'll peaked at? All stock+new muffler im getting a hair under 16. HBU?
Old Apr 1, 2008 | 08:37 PM
MiniJayhawk
I am still stock except for a CAI. I am getting about 14 at wide open throttle at higher gears. For instance, I have a hard time getting over 0 in forst. Second tops around 5psi. 3rd gear around 10psi. 4th on up gets around 14 briefly at full throttle to get her going at the higher gear. Pretty liner increase of peak through the gears, which makes sense. I would guess messing with the ECU would help improve the acceleration through boost increase.
Filmy
15
Jun 6, 2023 06:27 AM
schwac2
Oct 17, 2015 06:03 AM
paul7878
Sep 14, 2015 07:44 AM
mbatech
Sep 10, 2015 03:40 PM
Sep 2, 2015 11:15 AM
