Drivetrain do I need a re-tune?
Old Mar 24, 2008 | 04:48 PM
asbnil's Avatar
asbnil
Hi all!
My first post on this forum.
I tuned my MCS when I had 15% S/C pulley(+shorter belt), Milltek CatBack, K&N 57i Induction kit and Denso Iridium IK22 spark plugs installed.
After that I have fitted GRS intercooler, 40' volt coil pack and Magnecor spark leads.
I'm now going to install 380cc JCW Injectors, should I re-tune the ECU after the injectors are installed or will the ECU cope/adapt?
Advise is appreciatet!
Old Mar 24, 2008 | 05:10 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
With just 380's the ECU should adapt fine, but if you really want the most efficiency and power you will need a tune(not a GIAC), a Jan tune will do the job the best. And if you are looking to upgrade in the future skip the 380's and go to 400's or 440's... that + Jan's tune =
Old Mar 24, 2008 | 05:16 PM
asbnil's Avatar
asbnil
Thank's
I'm located i Norway, so I guess a Jan tune is difficult
Old Mar 24, 2008 | 07:01 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Well, for now it is...he is setting up the means to do remote tunes as well Or you could find a Dimsport(or many other brands) tuner in Europe that is renown for their work and have them go at it:thumbups:
Sorry for not noticing your location.
Old Mar 24, 2008 | 09:07 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
i would dyno the car before you add the injectors and see what the A/F is. just adding a pulley doesn't require injectors.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Mar 24, 2008 | 09:43 PM
asbnil's Avatar
asbnil
I was thinking that adding 380cc injectors was a smart move to avoid lean fuel and danger for early detonation at high revs. (Better to be safe than sorry!)
Old Mar 25, 2008 | 09:39 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
agokart makes a very good point.
And asbnil- you have the right idea...now just build on that...custom tune
Old Mar 25, 2008 | 10:06 AM
asbnil's Avatar
asbnil
I have just spoken with the guy who made my first ECU map. He recommended a new re-map to adjust for bigger injectors.
Thank's
Old Mar 25, 2008 | 11:56 AM
Bahamabart's Avatar
Bahamabart
Thank's
if you were happy w/ his first tune - follow his lead.
Old Mar 26, 2008 | 10:21 AM
asbnil's Avatar
asbnil
Thank's all
Will use RR when adjusting ECU map. Just waiting for my Milltek Manfold to arrive before installing injectors and a re-map.
Mb460
Sep 14, 2015 05:50 AM
RonG
Nov 20, 2013 05:53 PM
solskjaer1999
May 2, 2013 08:38 AM
Eggburp
Feb 5, 2012 07:20 AM
Grim Ryan
Apr 5, 2011 05:54 AM
