Drivetrain fuel pressure on R53?
Old Mar 22, 2008 | 06:06 PM
Jhud's Avatar
Jhud
after doing alot of research about injector sizes and B.S.F.C. and flow rates and such i am at the point where i believe its possible that i may need injectors. To be sure i need to know the correct fuel pressure on the R53 because it makes a big difference in CC/min especially on boosted vehicles. I belive that pressure is 3 1/2 BAR ( 52 psi ) but i need to be sure. apparently at 80% duty cycle a rough estimate at 52 psi would mean that stock injectors are only good to around 190hp. and JCW injectors will be sufficient to around 210hp.
Do these numbers seem realistic also? im kinda new to the tuning game and i dont want to install something i dont need or without getting all the info i can. thanks guys/gals
Old Mar 23, 2008 | 04:59 PM
ED955S's Avatar
ED955S
Contact Dinan and GT Tuning. They use > fuel pressure pump / adjuster in liue of higher flow rate injectors.
Old Mar 25, 2008 | 06:16 AM
Trickle X's Avatar
Trickle X
yes the FPR is 3.5 bar, so 51.45 psi & your math is dead on.
Old Apr 25, 2008 | 01:30 PM
daemon2's Avatar
daemon2
does anyone have the DINAN fuel pressure?
Old Apr 25, 2008 | 01:43 PM
Longboard110's Avatar
Longboard110
is 52 psi at idle or with key in on position but engine not started?
Old Apr 25, 2008 | 09:10 PM
k-huevo's Avatar
k-huevo
Healthy pressure readings:
Key on/no start/cold ~50-52 psi.
Idle 42 psi.
Under revs and key on hot ~60 psi.
Old Apr 26, 2008 | 01:32 AM
blue al's Avatar
blue al
whats anyones best guess for the lowest fuel pressure at which point the injectors fail to work effectivly.....
with respect to quality of fuel delivery, ie atomisation and spray pattern
is it better to keep up the pressure but for a shorter duration?
the math might stack up but will an injector work correctly with only 2.5 bar?
is there a lower limit to which they can be scaled?
is it better to use a tune, a adj fuel rail or both?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
David.R53
Sep 1, 2015 06:49 PM
vanhick
Aug 19, 2015 09:03 AM
