Drivetrain Install issue on MSD Coilpack
Old Mar 18, 2008 | 04:26 PM
virafp's Avatar
virafp
The factory bolts that hold down the coil pack have a sleeve on them, that prevents them from fitting the MSD coilpack.
Should I get replacement bolts, try and remove the sleeve and us the existing bolts or drill out the hole in th ecoil pack?
Any advice?
Viraf
Old Mar 18, 2008 | 06:06 PM
miniconcarne's Avatar
miniconcarne
Any advice?
Viraf
I used stainless steel all-thread and acorn nuts with stock rubber "bushings" on the bottom of coil pack. Left the MSD alone no modification.
Old Mar 18, 2008 | 06:18 PM
miniconcarne
You can use a 6mm socket head or button head screw, I had the acorns aready so I used them.
Old Mar 18, 2008 | 06:22 PM
spdfreak's Avatar
spdfreak
I took the stock bolts into a Fastenal dealer and had him match up the threads with bolts of equal length and purchased a set of washers to go with it. I also used the stock rubber bushings.
Old Mar 18, 2008 | 07:44 PM
canyonking's Avatar
canyonking
i didnt have any trouble, but if you are doo as other say..use the acorns and some stainless
Old Mar 19, 2008 | 08:36 AM
checkers's Avatar
checkers
Make sure the bolts or studs are the same length. I had a shop work on my car and when they reinstalled the coil pak they used longer bolts and went right throught the valve cover and caused an oil leak. They had to replace the valve cover it couldn't be repaired.
Old Mar 19, 2008 | 08:41 AM
agranger's Avatar
agranger
Same here. Except it was Home Depot to the rescue with the new bolts.
Old Mar 27, 2008 | 09:36 PM
silversmoke06's Avatar
silversmoke06
When i spoke with jan he seemed to think that the stock one was pretty killer
Just food for thought....
Old Mar 28, 2008 | 03:48 PM
chad1140's Avatar
chad1140
So now that you guys have your MSD's installed has there been any noticeable improvement in performance or MPG? Or how about quicker starts and smoother idle?
Old Mar 28, 2008 | 03:56 PM
miniconcarne
Not me, but it's RED .
Old Mar 28, 2008 | 06:20 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The MSD because it's red, produces an additional 20HP, but this is not measurable using normal equipment like Dynapack dynos or GTech accelerometers. However a properly calibrated butt dyno will reveal the truth about the HP gains.
Unfortunately, although I have the MSD coil pack, my popodyno is not calibrated, so I have not been able to detect the performance improvement over the 2 years of use.
Old Mar 28, 2008 | 07:25 PM
chadtoolio's Avatar
chadtoolio
Wasn't that coined the "Recto-Puckto-Meter"?
Old Mar 29, 2008 | 05:19 AM
agranger's Avatar
agranger
Yep... it's RED!!!!
I think that I noticed a bit less throttle lag after install, but not a huge difference.
Old Mar 29, 2008 | 10:39 AM
1FSTMINI's Avatar
1FSTMINI
if im not mistaken....it sounds like you pulled the sleeves out of the old coil mounts which do rust onto the bolts.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
yashmack
Aug 15, 2015 10:16 AM
