Drivetrain More Hp - Pulley or crank?
Old Mar 19, 2008 | 12:44 AM
  #26
Guest's Avatar
Guest
Originally Posted by trackster
If you had bothered to read some of the posts rather than just scan the grid you would have seen many testimonials to much more than 2500 miles . These are all from the thread I referred to and some of the odometer readings are over 2 years old . I am sure they may have added a few miles more as well and would have posted if they had a problem. I have also included a very well thought out post by Alta with regards to this rumor .
I should have said above as well as my Batman comment, that we have had ZERO reports of any issues from around the world. Several thousand crank pulleys sold, so if there were an issue I SWEAR we would have seen it. I trust it enough to put it on my GP (haven't made time to do it, but will ASAP!)
I skimmed the MINI2 thread above. I am skeptical that the cars reported to have failed, can be directly linked to the crank pulley as RMW seems to have implied. (I like Jan so no poke there.) I would suspect other factors caused those failures. My point is again, there are thousands of ALTA versions and who knows how many other mfr's of similar design, that if this was an issue we ALL would have heard about it long ago.
Just my two cents.
Adam T. adam@altaminiperformance.com
[FONT=Arial][SIZE=2]
[/SIZE][/FONT]103,000 miles, still track and autox. Crank pulley on for 80,000. Original supercharger.
Steve
The 16+2 combo has been great so far for 12k
A 15%+2%, Lots of street mile, and lots of track miles. not a problem.
Chad
Detroit Tuned
Both the Alta -15% and +2% pulleys, 22K miles, no problems.
A blast from the past. I still have my 3% crank pulley. You and I have almost the same mods, but I do not put too many miles in mine, do not have to, but would like to. I am at 37K in a 2003 MCS. Crazy. Not problems at all with my inspired driving.
15% supercharger pulley Alta
2% crank pulley Alta
15500 miles
M7 16%
M7 2%
28,000 miles
.M7 16% and Alta 2% no problems at 7500 miles. Did the conversion at 2200 miles. Also have an Alta 0% crank pulley available for sale 300 miles on
Alta 15% SC Pulley 45,000 miles
Alta 0% Crank Pulley 25,00 miles
Moved up to:
Alta 2% Crank Pulley 10,000 Miles
Track and Street, no problems and no Alt. Pulley.
Alta 15% 9000 miles and Alta 2% 5500 miles no problems what so ever.
15% Alta supercharger pulley: about 20,000 miles, ZERO problems
2% Alta Crank Pulley: about 9000 miles, again, ZERO problems
Alta 2% crank (15,000 miles) with Madness 15% SC (70,000) . . . perfecto
Alta 15% SC pulley - 40,000 miles - no problems
Alta 4% crank pulley - 15,000 miles - no problems
Alta, 2% (with 15%) 4000 miles, ZD. (Zero Defects)
Alta 0% with 19% pulley. 4000 miles, no problems.
04 MCS
SC: Alta 15%
CP: Alta 2%
Milage: 9k
Problems: zero
M7 16%
M7 2% crank
I have had mine on for at least 10K with no problems 0% w 19%
Alta 15% pulley (56,000 miles) no problems - now 88,000 miles
m7 2% crank pulley (9,000 miles) no problems - now 32,000 miles
You're more than welcome to put one on your car. I see no performance benefit, and would rather spend the money on something else that hasn't been proven to cause issues long term in THOUSANDS of examples across the entire car tuning community (Yes, there are cars other than MINI's ).
Old Mar 19, 2008 | 10:13 AM
  #27
eager2own's Avatar
eager2own
Sorry, didn't mean to bring up a topic, which as I noted has been covered elsewhere.
But since the can of worms is open, I will say that I find it hard to understand why MINI felt a dampener was needed in the MCS (when it wasn't on the MC), unless there's a reason for it.
Comments like the one I quote above are not very convincing because one can always write off engine failures to "other factors" when the mod in question is one that may be causing engine damage from prolonged use.
Use of the crank pulley especially makes little sense (to me) in light of the fact that it's more expensive to do a 15%+2% than a 17%, for example. But I'm glad there's others out there willing to test the concept.
Old Mar 19, 2008 | 10:23 AM
  #28
Revolution Mini Works's Avatar
All 4 engines that I personally saw had oil gear failures.... all had cracked into pieces... THE ONLY PART COMMON TO THESE ENGINES WAS THE CRANK PULLEY......... each was in its form of mods
coincidence... I'm sure of it
Old Mar 19, 2008 | 11:16 AM
  #29
JIMINNI's Avatar
JIMINNI
Originally Posted by rustyboy155
However much it has been gone over, there's no point, it doesn't make any power so it's a waste of money to begin with. It offers absolutely no performance benefit (We've tested them). The 05+ crank pulley is lighter, and accomplishes the same thing, without increasing the likelihood of it spinning off the crank and careening across the engine bay.
I happen to know at least 3 people who have gone through engines and spent thousands repairing damage caused by a crank pulley, so it can be argued both ways. What do you think they gained with a 2% pulley on top of a 15%, Considering the intake temps shoot up about 25-30 degrees with a 17%, and 40-50 with a 19%, do you really think you're actually accomplishing anything?
Tangent: Pistons and SC are fine? Nobody ever said anything about pistons or SC having issues if you use an aftermarket crank pulley. If your pistons have issues after putting a lightened crank on, uhh not sure what to tell you, the two have nothing to do with one another.
Hmm....didn't you say in the post before mine that a crank pulley would add 2-3hp? Now you say it does absouletly nothing. I know 2-3 hp really is not that much, but it is something. Then you also said in that same post: " the power comes from the fact that it spins the SC faster." That is why I mentioned the comment about the one guy having the same SC. Some people think pullies are causing SC's to spin too fast. I was told that crank pullies can help my 03 because first gear is higher than the later models. I did feel a difference when it was installed. Now this all being said, as soon as we can get Jan up here to do some tunning, then with all the extra power we get, i'll take it off .
Old Mar 19, 2008 | 11:19 AM
  #30
JIMINNI's Avatar
JIMINNI
Hey Jan did you recommend to all the guy's that got your tune to remove them? I'm sure alot of them have them on. I would like to take mine off once I get a tune.
Old Mar 19, 2008 | 11:25 AM
  #31
I always tell people to take them off If you saw the oil pump gears that I have you would too....
better to take it off before the tuning or your car will be tuned wrong
Old Mar 19, 2008 | 11:29 AM
  #32
JIMINNI's Avatar
JIMINNI
Ok . Hopefully soon?
Old Mar 19, 2008 | 12:47 PM
  #33
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Closer to the original question (didn't mean to interrupt) What is the supercharger boosting with just a 3% alone? 2%? 15% w/ 2% combo?
I have 30,000 miles on a 2% crank, no problems here...My old crank pulley is now used as a door stop. Very heavy (02). I noticed a faster revs all throughout the RPM range.
Old Mar 19, 2008 | 03:14 PM
  #34
D-MAN's Avatar
D-MAN
Jan I think you have just killed the mini crank pulley industry!!!!
Old Mar 19, 2008 | 05:23 PM
  #35
I highly doubt it.... people will do what they want.... it will help me sell crate engines though....
Old Mar 19, 2008 | 05:55 PM
  #36
Deviant's Avatar
Deviant
Got pictures of the oil-pump gears? I've always argued the harmonic balancer was important, photo proof would be great.
Also, is there a graph somewhere so you can get an estimate of boost levels for different setups? (Stock vs. JCW vs. 15% vs. 17% and then with the different % cranks?)
Old Mar 20, 2008 | 06:52 AM
  #37
eager2own's Avatar
eager2own
All I know is that there are a couple on the Marketplace
Old Mar 25, 2008 | 02:12 AM
  #38
bglct99's Avatar
bglct99
I have an '06 S and, much like the original poster, want more power out of it (it's bone stock right now). It sounds like a 15% is the least contested method for doing so. Does that sound about right, leaving a change to an aftermarket crank by the wayside?
Old Mar 25, 2008 | 03:54 AM
  #39
D-MAN's Avatar
D-MAN
My car is getting pullied next week - I am going to get before and after dynos.
I will post them along with the rest of the mods (header, head and custom tune).
Stay tuned....
Old Mar 26, 2008 | 04:19 AM
  #40
sraturbo's Avatar
sraturbo
Crank pulley reply
I have a Alta 4% on My 03 coop s I have had 0 problems with it. I have logged over 4000 miles with it vehicle runs great. Possibly the people who have had problems with it did not install it properly ? I used to be a Mini tech and I used the proper tools to put mine in. After installing it I cleared the adaptation values in the vehicle and noticed an imediate gain in performance and would recommend using it. I would however not recommend it for use on a automatic vehicle due to the fact that the vehicle has trouble with shift points.
Old Mar 26, 2008 | 10:25 AM
  #41
Guest's Avatar
Guest
Like most things that take time (Like saying "I've been smoking for 2 years and haven't noticed any problems! I'm less hungry because everything tastes like ashes, so I'm losing weight; everything is dandy!", meanwhile 20 years down the road you're dead from lung cancer), your engine isn't going to fail catastrophically after 4k miles of running without a harmonic balancer. It can, and will however shorten overall engine life.
Old Mar 26, 2008 | 10:27 AM
  #42
Guest's Avatar
Guest
Yes, spinning the SC 2-3% faster will make a few HP, at the expense of your SC spinning way over it's redline, and you pushing 120+ degree intake temperatures on the STREET.
As a member of the $20k+ mod club, that's 2-3 HP that I definitely do NOT want . I'm pretty sure Jan's joined the $100k+ mod club by now, and if he's nixing them (I'm sure he's spent a LOT more money chasing 3 HP) I want nothing to do with them.
Some info, with a 15% you're ALREADY spinning the M45 faster than it's intended spec, so it's not going to last as long as it would have. By changing your redline you've pretty much ensured premature failure of the SC (Reving the engine up another 1400k RPM's past it's previous redline isn't any different than running a 21-23% reduction on the SC). I've accepted this risk (I track my car, there's plenty more than my engine that I risk).
On the street, a quick 1st and 2nd gear pull up to redline in each will send my intake temps skyrocketing into 175 degree territory. If you think it's safe for your engine to combust 175 degree air all day long (You guys think a change in air temp from 65 to 85 degrees kills performance?) go ahead and throw all the reduction on you can.
There's a reason any website worth a damn says "A 19% pulley is for STREET USE ONLY" because prolonged time in the upper rev range with the M45 running at a speed that the 19% pushes it to can
, and will kill engine components.
Old Mar 26, 2008 | 04:18 PM
  #43
ScottinBend's Avatar
ScottinBend
Only 4K miles...........not nearly enough for any problems to show themselves. Is this with or without a pulley?
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
