Drivetrain i need a new belt for 15% pulley
Old Feb 19, 2008 | 05:45 PM
mini22's Avatar
mini22
what is the part # i need at what belt is best
Old Feb 19, 2008 | 06:14 PM
TWISTER's Avatar
TWISTER
you can use the stock belt
Old Feb 19, 2008 | 06:25 PM
the platform's Avatar
the platform
This is easy.....
Gatorback belt by Goodyear
part#4060537
thru Summit Racing
http://www.summitracing.com/
This belt is awesome.It enhances the whine of the S.C.,and makes a beautiful
winding noise.It felt like I got a tune up(compared to the p.o.s.belt I took off of it.)
Old Feb 19, 2008 | 06:31 PM
HighLife4136's Avatar
HighLife4136
Old Feb 19, 2008 | 07:18 PM
verveAbsolut's Avatar
verveAbsolut
Originally Posted by HighLife4136
Hahahaha HighLife...so it continues.
Use NAPA belt 25060539 or 25060535...or the Gatorback belt listed above.
NOT the stock belt.
- Matt
Old Feb 19, 2008 | 09:55 PM
HighLife4136
NOT the stock belt.
- Matt
Thanks Matt I was feeling a bit tired
Old May 4, 2008 | 02:00 PM
myzamboni's Avatar
myzamboni
NOT the stock belt.
- Matt
I've used a stock belt for 20K with zero issues.
Old May 4, 2008 | 02:38 PM
Luys's Avatar
Luys
you can use JCW belt
Old May 4, 2008 | 02:52 PM
thë_cöpi's Avatar
thë_cöpi
I was using a stock belt with a 15% pulley for 30K+ miles with "no issues" too - until I put my car on a dyno and saw that the belt was slipping and I was getting boost spikes and losing power. Then I got the NAPA 535 belt.
Old May 4, 2008 | 03:02 PM
Jhud's Avatar
Jhud
i assume the NAPA belt 539 is 4mm longer than the 535? which belt is better here? can it be too tight?
Old May 4, 2008 | 04:08 PM
orthomini's Avatar
orthomini
what the copi said. the napa 535 is correct. as long as it can be put on it shouldnt be too tight. i was using the gatorback 537 and the tensioner had no hole showing. now with the napa 535 the full hole plus is visible. mechanics have told me though that there is some error in all the belts so sometimes youll find the same size off by a bit.
Old May 4, 2008 | 04:41 PM
Jhud's Avatar
Jhud
I went to the NAPA website and could not find "25060535" i also manually typed in my engine and came up with this :
Shopping In-Store
Shopping Online
SHOPPING CART
CURRENT VEHICLE 2003 Mini Cooper Change Vehicle
NAPA STORE LOCATOR
GO
BROWSE ONLINE STORE
PartsPRO SE CATALOG
SEARCH PARTS & ACCESSORIES
by Keyword
GO
Job Type Search
QUICK LINKS
WANT TO LEARN MORE ABOUT NAPA?
function ProcessClick(event, type){ /* if(window.event) // IE { keynum = e.keyCode } else if(e.which) // Netscape/Firefox/Opera { keynum = e.which } keychar = String.fromCharCode(keynum) numcheck = /\d/ return !numcheck.test(keychar) } */ if ((event.which ? event.which : event.keyCode) == 13) { var elemId; if ( type == 'kw' ) { elemId = 'ctl00_mainContent1_ucHTMLContent_ctl00_LeftNav1_k eywordSearchLinkButton'; } else if ( type == 'pn' ) { elemId = 'ctl00_mainContent1_ucHTMLContent_ctl00_LeftNav1_p artNumberSearchLinkButton'; } else if ( type == 'oempn' ) { elemId = 'ctl00_mainContent1_ucHTMLContent_ctl00_LeftNav1_p artNumberNonNAPASearchLinkButton'; } else if ( type == 'zs' ) { elemId = 'ctl00_mainContent1_ucHTMLContent_ctl00_LeftNav1_z ipLinkButton'; } document.getElementById(elemId).click(); return false; }}
Browse Catalog >> Belts & Hoses
Vehicle: 2003 >> Mini >> Cooper >> Don't Know
[SIZE=3]Add Items to Cart[/SIZE][SIZE=3][/SIZE][SIZE=3][/SIZE]
The search returned 5 hits. Displayed are results 1 to 5.
<< Previous | 1
| Next >>
Product Name Item Number Price SelectBelt - A/C
Engine:1.6 L 1598 CC L4;
PBH
6K415 $12.99
Belt - A/C
NBH
25060415
$22.49
Belt - A/C
ATM
6PK1053 $20.69
Belt - Water Pump & Alternator
NBH
25060547
$24.49
Belt - Water Pump, Alternator & A/C
ATM
6PK1388 $25.59
<< Previous | 1
| Next >>
Basically I cant find the belt you guys recommend. a little help?
Old May 4, 2008 | 05:26 PM
minimusprime's Avatar
minimusprime
napa 060535
Old May 4, 2008 | 05:29 PM
verveAbsolut
Define "no issues."
I'd be almost certain you're getting belt slip on the supercharger (and not making peak boost) in your case.
- Matt
Old May 4, 2008 | 08:10 PM
Nitrominis's Avatar
Nitrominis
Define "no issues."
- Matt
Depends on who's pulley he is using.
Old May 4, 2008 | 11:02 PM
SharoSC02's Avatar
SharoSC02
Originally Posted by the platform
This is easy.....
part#4060537
thru Summit Racing
Is this the same size of Napa's 060537?? If so, I found it to be a little too big for the 15%.
Old May 5, 2008 | 11:02 AM
verveAbsolut
Not really. As long as he doesn't have an upsized crank pulley to take up the slack, any of the reductions should not be using the stock belt.
- Matt
Old May 20, 2008 | 09:07 AM
jblow's Avatar
jblow
Just to clarify, is the Napa 060535 or 060539 that is the best application for 15% reduction pulley and OEM crank?
Old May 20, 2008 | 09:37 AM
thë_cöpi's Avatar
thë_cöpi
Napa 060535
Old May 20, 2008 | 09:42 AM
thulchatt's Avatar
thulchatt
535 is the correct belt for 15%
Old May 20, 2008 | 11:54 AM
Guest's Avatar
Guest
Didn't say there will be problems, but if you want to actually get the most out of your pulley, use a belt that fits, not one that is so loose it starts slipping at 5k RPM's.
If you're going to have the pulley off anyway, why not spend $20 on a belt? If it snaps, it's going to cost you 20x that for a new crank pulley when it self destructs...
The 535 belt works well for a 15% pulley.
Old May 20, 2008 | 11:56 AM
Guest's Avatar
Guest
Removed all that crap cause the HTML makes it hard to read your question.
Give Danny a call at MINICorsa, he can recommend a place to get belts local to you.
Old May 21, 2008 | 08:11 AM
blkkouki's Avatar
blkkouki
so wich belt would you guys suggest for a 17% pulley
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
