Drivetrain Do turbo cars need CAIs?
Old Feb 3, 2008 | 08:02 PM
danielo's Avatar
danielo
This item popped up in one of the posts in a thread.
Just wanting some clarity here.
The turbo sucks in air and compresses it prior to the intake into the engine.
The air passes thru the turbines in the turbo which are spun by the hot exhaust gases, this makes the intake air hot.
So why bother with a cooler intake air, when it's gonna be heated anyways.
Isn't money better spent on water/methanol injection or a more efficient FMIC?
Old Feb 3, 2008 | 08:11 PM
e30r56's Avatar
e30r56
If the air is cooler as in enters the turbo, it won't warm up as much. There are gains to be made with all 3: CAI, water/meth. inj., and/or FMIC.
Old Feb 3, 2008 | 08:28 PM
danielo's Avatar
danielo
Which would be the best bang for buck of the 3?
Old Feb 3, 2008 | 09:15 PM
Li'l Red's Rider's Avatar
Li'l Red's Rider
The CAI.
The engine power is limited by how much oxygen an engine will pump. The CAI is less restrictive on the suction side of the turbo, and will flow more air more easily, more power.
Pump more air into an engine = more oxygen = more power. The air is heated when it is compressed by the turbo, yes, but the best way to say it is that it raises the temperature of the incoming air. Cooler air in, cooler air out. Denser air can carry more oxygen = more power. The air is mainly heated by compression, not by passing thru a hot turbine.
The intercooler also cools the compressed air, for higher density. The intercooler is especially needed in the summer months, as it will keep the engine from losing power from the less-dense air due to the hotter air temp. It will also allow more boost to be used, because it can remove the additional heat created by compressing the air to a higher pressure and temperature.
Old Feb 4, 2008 | 08:13 AM
Straius's Avatar
Straius
Perhaps a lot less important from a performance side...
But I love the bypass valve sound and turbo spin-up that you can hear as soon as you remove the stock air box. I find it really satisfying to hear the engine work and hear the sounds it produces that were hidden before by the OEM system.
Old Feb 4, 2008 | 08:24 AM
AstroBlackS's Avatar
AstroBlackS
+1. Love to hear everything going on!
Old Feb 4, 2008 | 08:36 AM
MiniJayhawk's Avatar
MiniJayhawk
The "C" in CAI isn't the ultimate benefit. If you can get some "C" in the equation then it helps, but isn't huge in the case of the Mini setup. I think it should be called an "LRAI" or Less Restrictive Air Intake.
Toolman
Jan 20, 2016 06:50 AM
tr3y003
Oct 22, 2015 10:48 AM
rckrzy1
Aug 11, 2015 06:06 PM
Aug 11, 2015 09:01 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
