Drivetrain AFTER OBX HEADER....vibration
Old Feb 15, 2008 | 12:53 PM
  #26
Guest's Avatar
Guest
Originally Posted by the platform
I shall do it sir,thanks.
The front portion of the exhaust set up has calmed down,for the most part.It only acts up on 1st drive of the day-sometimes.
I am noticing an increased vibration in the rear of catback now.Maybe the header is settling in,but the increased exhaust pulses are wiggling the milltek a bit more.
It's a funny curious game we play,when we choose to go faster!
I'm getting tuned by Jan next week,maybe that will smooth out things some.
Thanks Astro
Check with Jan before you wrap that OBX. I'm not sure what it's made out of, I think it's mild steel. That has a tendency to crack when you wrap it because of the excess heat and stress associated with heat cycling like that. The RMW header is 304 grade stainless and doesn't have that issue.
FYI I'm not knocking the OBX at all, I had it on my car for nearly 10,000 miles before I swapped it out for the complete RMW exhaust. It works great for what it is, but it's not going to compete with a $1,200 header .
Old Feb 15, 2008 | 08:04 PM
  #27
Bahamabart's Avatar
Bahamabart
Thanks Astro
So lets see if i understand you are not only having Jan increase your HP via a tune and eliminate your exhaust rattle?
Now there's a challenge for Jan
Hey Jan my drivers side window sticks - got tune for that
Old Feb 15, 2008 | 08:06 PM
  #28
Bahamabart's Avatar
Bahamabart
Originally Posted by rustyboy155
It's just a spring coupling, not a flex joint. I agree it can work just as well, unfortunately OBX Doesn't provide the proper length bolts, so you have to over-tighten the springs, and the nuts on the back have a tendency to back out if you have a really tight engine (Lots of stiff mounts like I have). The OEM style super flexible joints have lots of issues, but the flex joint on the RMW header is great. It's expensive, but works wonderfully.
How much actual flex is there in Jan's set-up. From a pic I saw it did not seem very flexy. Not saying its bad - just curious.
Old Feb 15, 2008 | 10:25 PM
  #29
the platform's Avatar
the platform
I'm glad i was able to serve you up such a good laugh.
However amusing,I posted with only a hint of seriousness in regard to the tune being able to end my vibration issue.It does seem to become rather alchemical though(the solutions to car problems).As far as the tune goes,I'll be satisfied with just a faster ride.
Old Feb 15, 2008 | 10:34 PM
  #30
the platform
According to Sparktec the obx is sus 304 stainless.
Old Feb 16, 2008 | 04:36 AM
  #31
Bahamabart's Avatar
Bahamabart
Just funning w/ ya. MORE importantly wanted to pull Jan's leg and give him a new challenge because giving people HP has become to easy for him. . I think we need to start coming up w/ special requests.
When I first installed mine , I had a little rattle and even though it sounded or felt that it came from the header - it ended up being the shield in the back. I played w/ that and it went away but I still get a little rattle when backing up under light rpms loads.
Try removing the rear shield and drive around and see if anything changes. Another thing perhaps to look at is the engine mount bushings. I saw one removed form a car that wasn't that old and the rubber had broken up.
Old Feb 16, 2008 | 06:35 AM
  #32
the platform
Bahama,
Those are all sound ideas.
It is bizarre how those vibrations travel.
I keep seeing recomends for poly bushings -my next endeavor.
On a somewhat related note:I'm changing out my injectors before tune.
Doc Obnx's blow by blow pics look helpful.Have you done this procedure?
Daunting?
Old Feb 16, 2008 | 10:11 AM
  #33
Bahamabart's Avatar
Bahamabart
Nope - still running stock Injectors. Until I I see myself running lean, I see no reason to change. Even w/ a custom tune, I'm still piggy rich up top so the last thing I need is more fuel. I added a WB O2 so I am now finally informed about things.
Jan's coming to Florida, I though I would give him a crack at my A/F otherwise I was thinking of doing a head/cam this summer so I would need a tune then.
Old Feb 16, 2008 | 10:14 AM
  #34
the platform
Nice!
Vaderm34
Sep 27, 2015 09:25 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
kyriian
Aug 2, 2006 10:14 AM
gobble
Mar 23, 2006 12:46 PM
Minirowski
Dec 18, 2005 06:45 AM
