Drivetrain Alta Pulley question..
So i got a good deal on an Alta S/C pulley and belt. I decided to install them on Sunday afternoon.
My question is, How do I know for sure what Alta size pulley it is? It is not stamped like some I have seen.
Also, the belt that came with it was a NAPA belt # 060539. But at high RPMs I can slightly smell it slipping. Boost gauge is hitting 17psi.
It is supposed to be a 19%.
Well you would have to get some calipers and do some math I imagine. The diameter times pie is the circumfrence (sp). Subtract the smaller one and that number should be 19% of the larger number. i am problably wrong, your boost sounds right.
I read on Alta's site that they recommend the NAPA belt #060535, mine came with the #060539 which is the one for a 2% crank pully.
Is there that much difference between the belts to go change it?
Hey not to pee in anyones pool. If that is genuine ALTA and a 19% it will have 19% engraved into it. Maybe it is a REALLY old 15%. The very first ones had no engraving as we hadn't made any other sizes.
Off forum can you kindly tell me where you got it? Want to be sure you got what you paid for and if not, lets warn others in the community!
patsum
26
May 29, 2021 06:29 PM
