Drivetrain DT Bypass Valve MPG and other Observations
Old Sep 26, 2008 | 11:24 AM
  #26
jtack's Avatar
jtack
Yes that is the screw that is easily broken. And yes the bypass valve still opens and closes the spring is just stiffer than stock and the butterfly valve goes fully closed instead allowing air to get through. My stock valve when closed wasnt actually closed. If you shine a light through the valve you can see an area around the flap that is still allowing air through. With the DT bypass valve I shined the light through and no light was able to get past the butterfly valve indicating a much better seal when closed which allows more boosted air to get to where it needs to go.
Old Sep 26, 2008 | 11:32 AM
  #27
jollyroger927's Avatar
jollyroger927
INteresting. I like this mod but the whole problem when your going slower bothers me. But i guess some things you cant fix if you want more power. I'll probably be getting this soon. Instilation isnt hard right? Does the radiator need to be removed?
Old Sep 26, 2008 | 01:28 PM
  #28
jtack's Avatar
jtack
no removal of the radiator.
Old Sep 26, 2008 | 03:38 PM
  #29
jollyroger927
Even better then. Thanks for the information!
Fordgt4
Oct 10, 2015 10:42 AM
Nicefeet
Sep 24, 2015 06:53 PM
smbmkay
Sep 11, 2015 09:45 AM
kjd186
Sep 9, 2015 10:02 AM
Gen1Parts
Sep 7, 2015 03:50 PM
