Drivetrain ALTA PWI-1 Water Injection Test!
Old May 22, 2009 | 01:48 PM
  #51
dtsoccer6's Avatar
dtsoccer6
sweet!! Thats the answer I was looking for!
Old May 22, 2009 | 02:15 PM
  #52
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by dtsoccer6
Um, you need to get a dyno and so I can see what these type of kits can do ...no CELs with your Uni?
RMW is coming out with one soon...will prob go that route, but interested to see numbers...keep us posted!
Jeff published numbers on our GT28 R56 some time back. I will try to post up the links shortly. But we will also post some more on a "regular" stock turbo R56 soon.
The kit will always make a larger difference on cars with non-standard boost levels.
As always, more to come!
Old May 24, 2009 | 06:47 PM
  #53
chakraj's Avatar
chakraj
Hey Adam, I need a little help here. I am going to hook it up using IDC, instead of MAP load. I can not find what wire to use from the fuel injector on my 2008 mini cooper s? Can you have Jeff, or Chris respond to this thread with the answer please. I called Chris and left a message last week with no response. Thanks Adam
Old May 26, 2009 | 10:10 AM
  #54
chakraj's Avatar
chakraj
OK I talked to Jeff this morning, he straightened me out. Thanks
Old May 26, 2009 | 10:45 AM
  #55
ADAMSALTAMINI
SO SORRY I didn't get to this over the weekend! Family, family, family!!!! (love em, but they can cut into my MINI time )
Glad they got you handled today!
Old Nov 7, 2012 | 11:04 AM
  #56
Hank Rearden's Avatar
Hank Rearden
Originally Posted by ALTA2
The PWI-2 system can do injector pulse pickup on a non-Direct injected car. But on the R56 you would use a 0-5V sensor like MAF or MAP. You could use TPS but it will not be very progressive.
Then for tuning at this point, nothing, but below may answer some of that question.
Well its not lean for a Direct Injected car. But lean compared to a normal turbo car. But yes WI does make it run richer, which is good and safe, but there is alot more to this story. In tuning the R56 with the Unichip and other ECU products the fueling is 100% closed loop. Meaning there is an AFR target and the ECU uses the Wideband 02 sensor to maintain this. Meaning the AFR will not change after the WI is install, also meaning the ECU is pulling fuel to meet the AFR target. Why this is weird is this happens under all loads not just cruise like normal cars.
An example is if a normal car is tuned to 11.0AFR, turning on the water/meth will make it .5AFR to 1 AFR richer. Leaning the AFR back to the same level is how we normally tune the fuel side of things. Going leaner can make more power, but that is the general rule. So with the R56, knowing that the AFR curve is just fine (yes can be better, but was very safe on our 280WHP R56) and knowing the ECU will lean it back out after the water is turned on its perfectly safe and it will make more power.
Well hard, is relative to your experience. I would say for a DIY'er with the normal basic tools and a auto parts store close by, not a problem at all. It would just take you about 2-4 hours depending on the tank and pump location. We will soon have some R56 specific instructions that will use the OEM washer tank. We feel this is the best solution as there isn't much room to run another tank in the engine bay. Using this for both windows and your Water Meth mixture is just fine. Windsheild washer fluid is already a meth/water mixture with a little detergent. Besides the water/meth mixture costing a bit more, not a big deal at all. Also the tank is rated for the mixture, and i feel its a better option than installing a tank in the trunk.
If you really don't want to use the front washer tank, a rear tank, with the pump mounted close to it or in the engine bay would work just fine, you may just need some more hose(which we stock).
Hope that all make sense.
Sorry, I know this is an old thread.
But I have one question regarding the A/F ratio on tuned Minis.
Mine was tuned, but I still see a 14.7 af/ratio. At any boost (even at 20 psi)
Only after a while after wot I see the A/F starts to gets richer reaching 11:1 in the end, but I´m afraid the engine could blow with 20 psi and 14.7 a/f before the upgraded map kicks in!
Old Nov 9, 2012 | 08:56 AM
  #57
ALTA_Chris's Avatar
ALTA_Chris
If you are running the factory tune, this is common. But normally on a custom tune, you wouldn't be seeing this. We posted a blog post about this a while back here.
If you have any more questions, feel free to PM.
rtk90
Aug 29, 2019 09:08 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
