Drivetrain In development: Helix front mount stepped-core
Old Nov 29, 2007 | 10:16 AM
Helix13mini's Avatar
Helix13mini
Over the last several months we have developed a new concept in intercooling for BMW applications, and decided to apply it to our R56 MINI. It utilizes dual-thickness cores to maximize both frontal area as well as core thickness. The end tanks are cast, and as you can see in the design pics, encompass both cores. The idea is to be able to install the intercooler without cutting or other permanent modifications, and fully utilize the space at the front of the car. The test prototype is being assembled as we speak and we expect to see it here soon.
Here's a side shot:
And here's a 3/4 view from the rear:
Old Nov 29, 2007 | 10:35 AM
MINIdriver85's Avatar
MINIdriver85
What are the advantages of the thicker lower part? I don't have a clear idea of the R56 engine bay as I have an R50 but my guess is that it would go further toward the centre of the engine bay, wouldn't this push that section too near to the engine itself, thus in an hot area?
Old Nov 29, 2007 | 11:33 AM
heyduard's Avatar
heyduard
the oem intercooler on the turbo'ed r556 looks to be about the size of the 'thicker' part. My guess is the new thinner section will go in front of the radiator.
Like everyone else, I have an opinion.
Old Nov 29, 2007 | 11:36 AM
Helix13mini
It's no closer to the engine than stock.
Old Nov 29, 2007 | 10:14 PM
MINIdriver85
Oh, ok then. thanks for the clarification
Yeah, I understood that from heyduard's post.
Old Nov 29, 2007 | 10:21 PM
scott48's Avatar
scott48
Looks like air flow inside could get turbulent.
Old Nov 29, 2007 | 10:25 PM
MINIdriver85
Which would be good for the heat exchange, from what my studies tell me However, if I don't remember bad, it could also cause a raise in the inlet/outlet losses...
Old Nov 30, 2007 | 12:18 AM
chuntington101's Avatar
chuntington101
nice idea!
what are the advantages over going for a thinner coore thats taller??? im just wondering why no one else has tried this yet.
Cheers
Chris.
Old Nov 30, 2007 | 12:24 AM
japper's Avatar
japper
Here's a side shot:
About time someone came up with this approach without any mods required to fit.
What about mounting points. Will this IC be secured at OEM points ?.
Old Nov 30, 2007 | 12:27 AM
japper's Avatar
japper
Originally Posted by chuntington101
nice idea!
Cheers
Chris.
This style has been done already by RMS in Germany. However it doesn't use factory mounting parts and thus requires drilling to the front crash beam to secure the upper edge of IC.
Old Nov 30, 2007 | 06:43 AM
Helix13mini
It uses the factory mounting brackets with no drilling.
Old Nov 30, 2007 | 07:00 AM
japper's Avatar
japper
Any idea of price yet.
Any dyno figures !.
Old Nov 30, 2007 | 07:17 AM
Helix13mini
We're not at that stage yet, but will of course post numbers and prices closer to release.
Old Nov 30, 2007 | 07:20 AM
Mini Fireman's Avatar
Mini Fireman
Looks like a winner. Looking forward to seeing it in use.
Old Nov 30, 2007 | 07:34 AM
minimusprime's Avatar
minimusprime
looks like a good design. Granted i don't know squat about ic development... but i'm sure helix will do everything necessary to make a quality product.
Old Nov 30, 2007 | 11:06 AM
going4speed's Avatar
going4speed
You may have an efficiency issue here. The lower core closest to your outlets will have the greatest resistance to air flow through the core.
A medium thickness core would have a higher efficiency I believe.
Here's a side shot:
Old Nov 30, 2007 | 12:53 PM
Mark@Helix's Avatar
Mark@Helix
I helped Eric design this intercooler, the entire core uses the same internal fin count so it will have the same resistance through the entire core. this design was done in order to maximize the available area in the front of the car, we streamlined every aspect of the cast endtanks to get air to flow as best we could. Once we recieve the final prototype we will run it through a battery of tests and dynos you guys will get plenty of data
Old Nov 30, 2007 | 01:08 PM
Helix13mini
I'm not sure where that speculation comes from. That has not been the case with the BMW intercoolers. Testing tells all.
Old Dec 1, 2007 | 06:13 AM
going4speed
Not trying to put the design down. Just something to keep in mind. The speculation comes from years of being an engineer. It is my job to optimize designs everyday.
Old Jan 4, 2008 | 01:32 PM
Helix13mini
From paper to metal
We have the first prototype, which we'll install as soon as we get a minute to breathe. We are booked solid through the fourth week in January, so our testing might be a little slow, but we'll keep you posted. Here it is:
Old Jan 4, 2008 | 10:06 PM
Msteadman's Avatar
Msteadman
Nice! Quite interested to see how the testing goes.
Old Jan 5, 2008 | 11:51 AM
going4speed
+1
Old Jan 5, 2008 | 12:21 PM
C2W's Avatar
C2W
+1
What he said. . . . .
Old Jan 5, 2008 | 12:27 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I was wondering if you guys were going to make this for the R56 after seeing it for the 3 Series on your adjoining site.
Old Jan 5, 2008 | 06:38 PM
Msteadman's Avatar
Msteadman
The IC above is for the R56. Or did I just read your question incorrectly???
