Drivetrain can you see the rear sway from behind the car?
Old Nov 12, 2007 | 09:22 AM
Raiyu's Avatar
Raiyu
I'm picking up a rear sway bar and considering getting it powdercoated. but if you can't see it then no reason right? please post pics if you can!
*edit* ugh accidentally posted in drivetrain and can't delete. sry!
Old Nov 12, 2007 | 11:30 AM
Jahmills's Avatar
Jahmills
No, you can't see it from the rear, it's mounted up through the rear subframe. You can see the ends of it through your wheels , just above the brake rotors, but only if you look for it or have really open wheels. Power coating would be a waste of money, unless you are concerned about it rusting, then just paint it.
Old Nov 13, 2007 | 01:22 AM
Raiyu's Avatar
Raiyu
gotcha was just curious
Old Nov 13, 2007 | 07:59 AM
ED955S's Avatar
ED955S
I have the H&R and it was colored almost brownish. To make it stand out from the wheel well, I painted the outer parts up to where the bushings with bright red 2 part epoxy polyamide. Just light sand the area to be painted to improve adhesion of the paint. Epoxy is as tough as thermoset powder coat. It's been 1.5 years without flaking.
Old Nov 13, 2007 | 11:03 AM
JC Scooper's Avatar
JC Scooper
Here's a pic of my Alta 19 mm (red) seen through the wheel:
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
