Drivetrain Header Bolts
Old Nov 6, 2007 | 02:22 PM
AstroBlackS's Avatar
AstroBlackS
Header Bolts
I have just ordered an OBX header w/ cat from helix...
http://www.helix13.com/mini/products/exhaust (at bottom of page)
...and while researching info about header installs, I came across something about the stock header bolts not being suitable for re-use. I.E. - they are only meant to be installed once, after that, the little teeth that grip the header are worn out and thus, loosen very easily.
Has anyone else heard of this? Should I consider getting new header bolts? I know mini-madness sells locking header bolts supposedly for this exact issue. Thanks!
Old Nov 6, 2007 | 03:54 PM
trackster's Avatar
trackster
It's always a good idea to use new bolts in this application . ARP is an outstanding supplier and easily sourced.
Old Nov 6, 2007 | 04:06 PM
tennis_man's Avatar
tennis_man
I use locking header bolts which are reusable. Can be found here: http://www.mini-madness.com/index.as...ROD&ProdID=270
Old Nov 6, 2007 | 04:16 PM
AstroBlackS
Thanks for the feedback! I'm defnitely leaning towards the locking header bolts now.
Old Nov 7, 2007 | 05:40 AM
TUFFMINI's Avatar
TUFFMINI
Locking-bolts
i also use the locking bolts from http://www.mini-madness.com/index.as...ROD&ProdID=270, and have not had one problem with them. Sure is nice not having to worry about a leak or loosing a bolt.
Last edited by TUFFMINI; Nov 7, 2007 at 05:43 AM. Reason: insure you know what bolts I use
Old Nov 7, 2007 | 07:56 PM
Trickle X's Avatar
Trickle X
hogwash.....tighten them back up......i've had the stock ones on & off probably more than anyone and never had an issue....but Yes you should replace them.....ive just been to lazy......hehe
Old Nov 8, 2007 | 04:12 AM
polizei's Avatar
polizei
I didn't replace mine either...oops. I haven't had a problem though.
-Cody
Old Nov 8, 2007 | 05:45 PM
AstroBlackS
Well, the header came in. I Can't seem to get the springs compressed enough to thread the nuts on the bolts that came with the header. Anyone have any ideas?
Old Nov 8, 2007 | 06:23 PM
AstroBlackS
scratch that. Bolted it differently.
Old Apr 7, 2008 | 08:05 AM
curv872's Avatar
curv872
Does anyone know the OEM part number for new header bolts?
Old Apr 7, 2008 | 08:15 AM
SRTech's Avatar
SRTech
07 13 6 800 269
Old Apr 7, 2008 | 08:54 AM
Bahamabart's Avatar
Bahamabart
I did re-use mine but buying new ones is a good idea.
Old Apr 7, 2008 | 10:35 AM
CooperStL's Avatar
CooperStL
I am also interested in the OBX/Random set-up. Any photos?
Old Apr 7, 2008 | 08:33 PM
AstroBlackS
sorry. No photos of it in the car.
I also reused my header bolts, but have a 2nd set in the closet if the need should ever arise.
Tires, Wheels & Brakes
Sep 14, 2015 11:34 AM
Sep 10, 2015 01:29 PM
Sep 10, 2015 10:52 AM
Sep 4, 2015 12:17 PM
