Drivetrain ALTA GAUGES...
Old Oct 23, 2007 | 02:48 PM
Maverick's Avatar
Maverick
ALTA GAUGES...
Hey,what about ALTA gauges for R56...?
They should have been ready days ago!
Old Oct 23, 2007 | 06:09 PM
ALTAPerformance's Avatar
ALTAPerformance
Hey low! Thank you for your post. I am finishing the details (making things perfect) and there is a sneak photo in the Dyno Test n-Tune
Sorry for the delay. PLUS the ECU stuff we have been working a ton on.
Back to the dyno!
Have a great night.
Adam@altaminiperformance.com
Old Oct 23, 2007 | 08:08 PM
C2W's Avatar
C2W
Hopefully for Christmas (and hopefully my DS MSC will be here by then). . . .
Old Oct 24, 2007 | 06:34 AM
ALTAPerformance
It will DEFINITELY be before Christmas (the gauge pod that is. I don't have a magic ball for your car. But for your sake I hope it arrives early!)
adam@altaminiperformance.com
Old Oct 24, 2007 | 03:30 PM
Maverick's Avatar
Maverick
OOOOk! Prepare to send the gauges in Italy! Anyway,what about the packages that are going to be available? Such as turbo boost+oil temp or turbo boost+EGT and so on...
Is it possible to have the temps in degrees centigrade?
Old Oct 24, 2007 | 06:07 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
The current ones are only in psi, deg f. etc. I may be able to get metric for my overseas friends.
Best to e-mail me at work and I will get back asap.
Thank you!
Old Nov 14, 2007 | 11:20 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Hey Adam, any word on when these will be ready for R56? They look sweet.
Old Nov 14, 2007 | 12:08 PM
ALTAPerformance
I just showed them actually to a local client that stopped by! He loved them. I pushed back delivery a bit so we could concentrate on a couple items before hand. Still going strong toward a Dec. (early) release. Sorry for the delay. Please don't think we are dragging our heels!
Adam
Old Nov 14, 2007 | 01:07 PM
C2W's Avatar
C2W
Adam
Should be ready about the same time as my S. . . . We need PIX Adam!!
Old Nov 15, 2007 | 07:11 PM
ADAMSALTAMINI
There is a sneak peak on the ECU thread here as well. I know this one is long in the making, but as always it WILL be worth it!
Chat soon!
Old Feb 4, 2008 | 08:25 AM
th3118's Avatar
th3118
Update?
Old Feb 4, 2008 | 08:28 AM
MiniJayhawk's Avatar
MiniJayhawk
YEAH! UPDATE! UPDATE! UPDATE!
Old Feb 4, 2008 | 03:45 PM
ADAMSALTAMINI
Currently being sold but not on the website. My bad! Working on that as we speak!
Sorry for the delay!
Old Feb 4, 2008 | 04:35 PM
ghosthound's Avatar
ghosthound
are they plug and play? Also, do they come with white faces?
Old Feb 4, 2008 | 05:49 PM
n1tr0's Avatar
n1tr0
I never realized (before it arrived) that the R56 MCS has no way to view the water temp
Here's to hoping your setup has a clean factory looking install & gauge for that
btw, business hours would be another great addition to the website, did a wishful drive-by this past weekend.
Old Feb 4, 2008 | 06:57 PM
scott48's Avatar
scott48
Engine off:
Engine on(lights off):
Engine on(lights on):
You can wire it up differently to have different color with lights on/off.
Old Feb 4, 2008 | 08:48 PM
MiniJayhawk
Do you have a solution for tapping into oil temp and/or pressure?
Old Feb 4, 2008 | 10:20 PM
Minidrivr's Avatar
Minidrivr
Any white background like the stock one?
Old Feb 5, 2008 | 10:45 AM
ADAMSALTAMINI
They are white during the day (lighting) and amber at night. Is that what you meant?
White faces aren't available.
Old Feb 5, 2008 | 10:47 AM
ADAMSALTAMINI
Thanks for the tip! We will be opening on Saturdays soon. (I believe after the Grand Opening.)
Yes water temp is just the same as the boost. Installs easily as well. I had them in Howard that way and really found it beneficial. Especially when using the ALTA PnP ECU.
Thanks again!
Old Feb 5, 2008 | 10:48 AM
ADAMSALTAMINI
Not plug n play. Does require some MINOR wiring for illumination, power and ground. But the instructions do depict how to do that. There is no drilling in the car etc.
White faces, not available. Sorry!
Old Feb 5, 2008 | 10:49 AM
ADAMSALTAMINI
Just checked my e-mail and they will be on our website later today. More info will start filling each of the tabs in the coming days. I told them the pricing and photos were most important for now.
chat soon!
Old Feb 5, 2008 | 04:33 PM
ADAMSALTAMINI
Hey guys quick note to those that got some of the first shipments. WE discovered today that Four kits went out that are missing two relatively crucial items to connect the boost gauge and the gauge pod to the Tach.
1) 1/8 NPT 1/8" Nipple
2) (2) Screws
If you have a kit be sure to open it and find out if these are missing if so contact me ASAP. Sorry for any inconvenience!
Old Feb 5, 2008 | 06:23 PM
Minidrivr's Avatar
Minidrivr
That's a bummer. Having gauges that don't match just look bad to me.
Old Feb 5, 2008 | 07:10 PM
spfdhed's Avatar
spfdhed
Actually, I just installed the gauges (not hooked up, etc as I am one of the 4 noted in the prior post) and they look really good. I will post pictures as soon as they are all ready to go. One thought would be to add the satin black faces to the tach and speedo if your really want a color match. But, I think you will be surprised (I was ) as the plastic match is very good and the hoods on the gauges adds to the "pod" effect of the tach and gauges.
