Drivetrain Short shifter
Old Oct 15, 2007 | 04:11 AM
ViVi^BoY's Avatar
ViVi^BoY
Short shifter
Hi
I'm looking at Helix Short Shifter and Alta Short Shifter.
Just wondering anyone encounter any problems with both the shifter?
Any other recommendation on other brand short shifter?>
Thanks guyz.
Old Oct 15, 2007 | 05:18 AM
ceo51378's Avatar
ceo51378
I've had a Helix SS on my car for about 40K miles with absolutely no problems. It has a shorter throw than the Alta and is much, much easier to install. Then again, the Alta has more bling and it is adjustable. For me, I didn't need an adjustable shifter - and that was worth the $130+ I saved. The Helix extension also leaves the shifter at it's stock height.
....on another note... you could get a Helix short shift & Pulley with $$ left over. Now that's a real performance increase
Old Oct 15, 2007 | 05:39 AM
MiniMacPR's Avatar
MiniMacPR
I love the Helix S/S, never tried the Alta so I can't give you feedback on it.
My experience with the Helix:
1. If you have a catback with a resonator (ala Milltek) there is very little space for the extension. I had to lower the exhaust piping about 1" to avoid interference.
2. Some (including myself) feel heat through the shifter if the windows and/or sunroof is open while driving. Others don't have the same experience .
Other than those two things I absolutely love it.
Use the search, you will find my thread and others...
Old Oct 15, 2007 | 05:46 AM
ceo51378's Avatar
ceo51378
That is true. With the Helix SS, you will need to permantely remove the bottom panel to your shift box. The heat shield will be plenty to keep dust and dirt out but you will feel a little heat form the exhaust. I also had to take out my heat shield and give it a few small taps from a rubber malet to give enough clearance for the shifter.
Old Oct 15, 2007 | 06:49 AM
eager2own's Avatar
eager2own
I had the Helix and loved it. i did experience the increased heat coming through, but it was not a problem (took me a couple months to notice for the first time), and I think that most, if not all, kits require removal of the bottom panel.*
Bottom line is: Helix cheaper and easy to install, but not adjustable, Alta more expensive but adjustable . . . so which do you need?
If you're looking for an adjustable shifter, also consider the Craven.
Edit- * and I know there's at least one thread out there about ways to reduce the heat 'leak'. Some have kept the bottom panel with a cutout to accomodate the shifter extension, while others have wrapped insulation around the exhaust.
Old Oct 15, 2007 | 08:29 AM
pauliekeys's Avatar
pauliekeys
I'll throw in a bid for the Craven Speed SS. I like the fact that I can adjust it and the shifts are very tight. At last years AMVIV I bought a Craven Speed shift well cover to go with it. It looks very nice and also blocks heat from the exhaust. The Whalen shift **** is also a must IMOP .
Old Oct 15, 2007 | 01:12 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I have the Alta SSK, with a new addition, a Whalen "Misfit" shifter. I absolutely love it. One of the best improvements is that the shifter does not feel flimsy like it could break when I throw it now. I can play with the adjustments very easily and I have had no problems in the year I have had it on my car. To me it was worth the money.
Old Oct 15, 2007 | 04:12 PM
ViVi^BoY's Avatar
ViVi^BoY
I see..
Thanks guyz for giving me those information.
May i know how short is the helix or alta?
Is it almost like Subaru STI '02 or S2000?
Old Oct 15, 2007 | 04:18 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
If I remember correctly(as to how an S2000 is) my Alta can go as low as an S2000, but also higher than stock mini.
Old Oct 15, 2007 | 04:43 PM
eager2own's Avatar
eager2own
The Helix does not change the height of the shifter (can't believe I didn't mention that difference above). . . so if you like stock height stay with Helix, but go with Alta or Craven if you want to actually change the height of the shifter.
If you're asking how much it shortens the throws -- I'd guess the Helix provides about a 33% reduction in throws.
Old Oct 15, 2007 | 04:45 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I do not remember what the %'s are for the Alta, but it is plenty short if you want it that short. Or even a little more(taller than stock).
Old Oct 15, 2007 | 05:18 PM
MRmidge's Avatar
MRmidge
I have the B&M ssk and love it. It comes with 4 aluminum bushings that replace the rubber ones on the stock shift housing. Making the shifts and shifter feel rock solid. If your going to get a fixed ssk, get the B&M or atleast look into trying to find the aluminum bushings for the shift housing.
Old Oct 15, 2007 | 11:31 PM
ViVi^BoY's Avatar
ViVi^BoY
I see i see
Thanks guyz
Will think over about it .. :D
Old Apr 15, 2008 | 05:38 PM
miniconcarne's Avatar
miniconcarne
Old thread..
but searched for a newer one. Anywho..I just installed the Rouge Engineering Short Shifter/extention dude, man what a difference. Should have done this sooner! I wish I had the cabbage to spring for the whole SS from (insert fav. vendor), this will definatley hold me over till then.
Old Apr 16, 2008 | 04:29 AM
THE ITCH's Avatar
THE ITCH
I doubt that you would notice any difference between the two other than the adjustability. If you are happy with the position of your shifter you have made the right choice and saved $ and install time.
Steve
Old Apr 16, 2008 | 01:01 PM
jtack's Avatar
jtack
can you post a link to this part...i tried to google but came up with nothing.
thanks!
Old Apr 16, 2008 | 03:16 PM
miniconcarne
Didn't see this on their web site, I bought mine used from a fellow NAMer.
But, Helix 13 makes one, Detroit Tuned sells them also(helix).
http://www.detroittuned.com/products...ion=powertrain
http://www.helix13.com/mini/products/suspension-chasis Four Items down.
Old Apr 17, 2008 | 07:38 AM
jtack's Avatar
jtack
thanks for the link! How hard is the install? Does the exhaust need to be dropped?
Old Apr 17, 2008 | 12:09 PM
THE ITCH's Avatar
THE ITCH
jtack
You do need to unbolt the cat from the exhaust in the front and also the front support and then let the exhaust just hang down. There is no need to go any further. After that just remove the heat sheild and then the bottom of the shifter box. Remove one cable and install the extention. You will not reinstall the bottom of the shifter box and it really is not needed. You can do a search for short shifters and several DIY will come up. It really is an easy project.
Steve
Old Apr 17, 2008 | 02:21 PM
Luys's Avatar
Luys
Are there pictures for ALTA or Helix short shifter ?
Old Apr 17, 2008 | 05:15 PM
miniconcarne
Originally Posted by THE ITCH
jtack
Steve
Spot on!
Old Apr 17, 2008 | 05:19 PM
miniconcarne
Technically it's an extender of the shift arm under the pivot point. Not an entire "short shifter". Stock shifter length is the same the "throw" is shorter.
Old Apr 17, 2008 | 06:10 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
What pictures are you looking for? I can gladly help. Just send me a Pm if you want!
Old Apr 17, 2008 | 06:12 PM
ADAMSALTAMINI
Also (not to rag on the competition) we have had reports from clients using the style shown above, that they came loose, or even fell off the OEM shaft after some time.
Is that installation error, or product fault? Seems like it may be the part as a set screw to hold all of that force, for that many uses seems concerning.
Just curious!
Old Apr 18, 2008 | 08:10 AM
Helix13mini's Avatar
Helix13mini
Just curious!
Come on Adam, you're not curious, you are trying to cast doubt about the efficacy of our shifter so as to sell your. Let's call a spade a spade.
