Drivetrain Do it yourself pulley install
Old Sep 18, 2007 | 03:41 PM
  #26
xsmini's Avatar
xsmini
Originally Posted by pinkmini
I was wondering where is the link to the instructions??
Try this at Webb Motorsports, its the one I used.
Nik
Old Sep 20, 2007 | 02:28 PM
  #27
HHFD633's Avatar
HHFD633
has anyone used a differant method. i have heard that you really dont need to do half of what the how to section here says.
Old Sep 20, 2007 | 03:59 PM
  #28
ScottRiqui's Avatar
ScottRiqui
Is there a particular step in Randy's instructions that you're curious about whether or not it's required? I know that some people do the swap without removing the airbox, but considering how much I have to raise the engine to get the pully puller in place, I can't imagine doing it with the airbox still installed without something binding.
Also, I only use one floor jack instead of two. I have three floor jacks, but I've never had any real difficulties getting things to line up with one, so that's all I use.
Most of the other steps in Randy's directions are pretty much mandatory, unless you have one of the pully pullers that lets you remove the pully without first removing the tensioner.
Old Sep 20, 2007 | 06:34 PM
  #29
HHFD633's Avatar
HHFD633
i have heard that the one that madness sells, you can skip most of the steps. ie: removing airbox and only removing pulley side motor mounts. anyone heard of this?
Old Sep 20, 2007 | 06:56 PM
  #30
El_Griton's Avatar
El_Griton
no you have to still take off the pulley side motor mounts. what you dont have to take off is the belt tensioner.
Old Sep 20, 2007 | 07:13 PM
  #31
ScottRiqui's Avatar
ScottRiqui
I think he's asking if you can leave the *motor* side engine mount bolts and airbox in place. I've only used the Alta Professional puller, so I don't know about the Mini Madness one.
Although if I had known when I bought the Alta that I'd be doing so many pulley swaps, I think I'd have gone with the MM one, just to be able to leave the tensioner in place.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
