Drivetrain GP engine support/damper
Old Sep 4, 2007 | 11:01 AM
SteveS's Avatar
SteveS
Just noticed the factory passenger side engine support/damper on the GP:
Is this available to everyone? It would seem to be a step in the direction of reducing failures. There is a bracket which bolts to the strut tower so the engine moves not at all. This seems to be a convenient method which does not interfere with access to pulley belt.
Attached Thumbnails GP engine support/damper-mini-cooper-damper.jpg
Old Sep 4, 2007 | 12:11 PM
Partsman's Avatar
Partsman
Legion_of_Doom
After 12/03, they were all setup like that.
I believe the mounts will still leak/fail even with the design change.
Old Sep 4, 2007 | 12:15 PM
MiniMacPR's Avatar
MiniMacPR
^^^ What he said is true
Old Sep 4, 2007 | 02:00 PM
kapps's Avatar
kapps
I don't think the mounts leaked before the design change. I haven't heard of any 02's or early '03's with leaky mounts, only after.
Old Sep 4, 2007 | 02:12 PM
Mini Works's Avatar
Mini Works
The mounts on the 02 and 03 are rubber,
they do not leak, but they come appart,
if your engine mount appears collapsed, it is probably broken,
the strap around the mount keeps in together, even when it is broken.
check yours out
Old Sep 4, 2007 | 04:18 PM
SteveS's Avatar
SteveS
My mini is 1/2003 MCS. The passenger motor mount leaked and so was replaced on warranty on 8/8/06 at 39600mi. My mount is the wrapped rubber kind. Does new one ( a la GP) replace it or can it replace it? Think here I can do away with the TSW style damper.
Old Sep 4, 2007 | 05:24 PM
rhawth99's Avatar
rhawth99
Yep, I'm taking my '06 in to have the mount replaced as it has leaked.
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
