Drivetrain 17% pulley
Old Sep 3, 2007 | 04:08 PM
HHFD633's Avatar
HHFD633
17% pulley
Please dont beat my *** for this. I know this issue of pulley sizes is getting old. I did do a search and there are so many post i just dont have the hours to look thru them so here i go . I would like to try a 17% pulley on my stock S using a 17% pulley is there any thing else recomended to do when using this size pulley.
I have heard colder plugs, plug and wires, belt. What do YOU think? I do plan to use a gatorback belt but other then that let me have it.
thanks
Old Sep 3, 2007 | 04:18 PM
gvoelker's Avatar
gvoelker
I run 17%.
I have colder plugs, larger injectors (380 cc jcw), and GIAC software. It pulls a lot smoother and doesn't knock NEARLY as often. And yes, it will be a lot quicker . I envy your tranny. The 06 will be speedier than mine!
Old Sep 3, 2007 | 05:12 PM
El_Griton's Avatar
El_Griton
One stage cooler plugs, injectors, and a flash will have you smokin the tires. these will make sure you dont run lean, a problem with 17% and smaller pulleys.
some other mods to look at would be a cold air intake and exhaust. many companies offer package deals that will have most of this stuff. here are a couple:
http://www.helix13.com/mini/products/packages
http://www.altaminiperformance.com/p...ory=23&model=8
http://www.mini-madness.com/index.as...S&Category=211
personally I am running the madness stage 2+ lots of extras. enjoy.
Old Sep 4, 2007 | 04:49 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
True, the must haves are the pulley (or a 15% S/C and 2% crank for better belt wrap), double check the tensioner for wear, new belt, some brand of puller to get the old one off. Spark plugs are a great idea (and inexpensive for the benefit), injecotrs (when paired with proper ECU tuning) are also nice additions. But for sure doing a 17% without an ALTA intake would be a shame :-) Seriously though that much extra wind will really require more incoming air to have it work properly.
Let me/us know if we can help further. Enjoy the new power when you get it!
Old Sep 5, 2007 | 04:37 PM
HHFD633's Avatar
HHFD633
thanks guys.. i ordered the 17% today upon install the pulley will accomponied by gatorback belt and colder plugs. intake and ecu will come later. i just want to make sure i am on the right track with this.
Any plug ideas? NGK? Denso?
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
