Drivetrain M7 Aerogel Heat Shield
Old Aug 14, 2007 | 12:28 PM
MaxMini81's Avatar
MaxMini81
Wanderer
I'm just wondering where this actually goes, and if anyone has it. Its cheap and looks good on paper, but does it do anything?
Old Aug 14, 2007 | 03:41 PM
MaxMini81's Avatar
MaxMini81
Wanderer
ok then
ok then... i guess ill try it and figure it out for myself and let you guys know... BUT if you know anything about it (esp if its pointless) let me know ill prolly order it tomorrow
Old Aug 14, 2007 | 04:32 PM
Johan's Avatar
Johan
There are 2 differnt heat sheilds.
One goes over your header or exhaust manifold, the other goes under the intercooler.
Old Aug 14, 2007 | 04:38 PM
Aeromax's Avatar
Aeromax
I've heard somewhere that it actually promotes heatsoak instead of preventing it, but I have no experience personally. I personally wouldn't bother with it.
Old Aug 14, 2007 | 05:54 PM
ScottinBend's Avatar
ScottinBend
I installed one before my last trackday and I was really impressed with how much cooler my PS fluid was. I also didn't notice any coolant residue around the tank.
The only concern I have seen posted was about under-hood air flow. I just re-adjusted the heat shield above the header to allow a bit more room above the aerogel. I have noticed no ill effects since installing it 3 months ago.
Old Aug 14, 2007 | 08:12 PM
MaxMini81's Avatar
MaxMini81
Wanderer
So, there are two heat shields, an exhaust and I/C.... but the I/C is only for the M7 or Alta direct flow I/C's right? IE... it would be impractial for the stock one? (I plan to get a better one, but cant afford it now)
Old Aug 14, 2007 | 08:19 PM
70spop's Avatar
70spop
I don't have either, so I'm just passing along hearsay. From what I've been told and read in other threads, the one that goes over the exhaust is a decent idea as it helps keep some of the heat from the exhaust manifold out of the engine compartment, and therefor away from the intake. I don't recall hearing any negatives about it.
The one that goes under the intercooler is really best used only with the DFIC. If you put it under a stock type downflow intercooler, it can actually block the path of the air exiting the cooler - not good.
Old Aug 15, 2007 | 05:34 PM
ScottinBend
Correct.
Here are a couple of pics of mine.
Old Aug 15, 2007 | 06:53 PM
Longboard110's Avatar
Longboard110
so what keeps the heat from rising UP and AROUND this?
Old Aug 15, 2007 | 07:00 PM
ScottinBend
I am sure you will get some, but nowhere near what it was before. I know from my own installation the both of the reservoirs are cooler than before. I have also adjusted the metal heat shield down a bit to allow a little more airflow over the top of the blanket. The concern brought up by another member was the possibility of reducing needed airflow from under the hood. I have no way of substantiating this, but figured it couldn't hurt.......lol
Old Aug 15, 2007 | 07:08 PM
Longboard110
I just think wrapping the header/exhaust manifold is cheaper and more efficient.
Old Aug 15, 2007 | 07:15 PM
ScottinBend
There have been some posts about that and in my opinion wan't as good an alternative. Wrapping the header may reduce the temps, but it will shorten the life of the header. Plus this was a 2 minute install.
Old Aug 15, 2007 | 07:20 PM
Longboard110
a combo of both would obviously be optimum
Old Aug 15, 2007 | 07:22 PM
jimz68's Avatar
jimz68
I have one of the exhaust "blankies",too. Using an infra-red thermometer, I measured 155F on the top of the rocker cover and 120F on the blanket. That was after a "spirited" run on my local twisty road, with the engine still idling. I know....I should have done a whole "before and after". Maybe next week.
Jim
Old Mar 11, 2013 | 04:03 PM
RA082324's Avatar
RA082324
does anybody have an actual numbers for temp differences? anything at all. coolant res, power steering, general area above heatshield... im pretty much about to buy this thing, but im just curious. last post was over 5 years ago. somebodys gotta have some updates or info on this.
dgamblin
Jan 2, 2021 02:57 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
potterstein
Oct 1, 2015 07:10 AM
M7Speed
Oct 1, 2015 07:05 AM
