Drivetrain suspension question
Old Jun 6, 2003 | 10:44 AM
sanity29's Avatar
sanity29
for those of you who have upgraded you suspension. did you do springs ans shocks or jsut springs? i guess my real question is, i'm planning on putting h&r springs on, and was carious if i can get away with just springs and not do the stock shocks? will the stock shcoks beable to handle the lowering springs without any damage done?
the reason i askis because some springs (depending on what ones you get) require you to replace the shocks to a more performance shock to make up for the shorter travel the springs give.
thanx
ja
_________________
new toy: 02 mini "S"
always remebered and missed:
92 VW Corrado VR6 -VSR
spoilers up!
CCA
I'm looking for a new graphics/
animation related job. can you help?
Old Jun 6, 2003 | 01:10 PM
picoman's Avatar
picoman
I got the H-sport springs and swaybar but didn't touch the shocks. From the many other posts out there, seems like people don't replace the shocks.
I would think that it doesn't matter since the shock is only there to to cushion the "blow" so to speak and not act as part of the suspension performance. I could be wrong but I never even thought to replace shocks.
just my $0.02 worth.
Old Jun 7, 2003 | 03:27 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I installed H-sport springs ($240) and madness rear swaybar($190). Kept the stock shocks and it is doing fine. With coil overs you can do more fine tuning and you get a stiffer ride and do more lowering of the car but all for a higher price $1500 to $1900.
So for lower cost and not too much lowering of the car (1 inch all around) with minimal adjustability- the H-sport springs are good. Rear swaybar helps to reduce understeer further and complements the springs. Newest model bar comes with three hole settings for firmness. The HR and H-sport springs are designed to work with the stock shocks. The HR lowers the car a bit more than the H-sport.
Old Jun 7, 2003 | 04:13 AM
LaBoy_Mini's Avatar
LaBoy_Mini
You can get both the front/rear bar at
H-Sport for only $344.00 1 Pair
it is much better deal for the two then just go and get the front only.
http://www.h-sport.com/
Tubular Anti-Roll Bar Kit
Finally! A tubular anti-roll bar set with adjustability at both front and rear! H-Sport's anti-roll bar set greatly reduces the roll characteristics of the Mini without sacrificing ride quality. A huge handling improvement and a lot of fun to adjust and feel both front and rear.
27MM FRONT / 19MM REAR
2 POSITION FRONT AND 2 POSITION REAR
POLYURETHANE BUSHINGS AND BRACKETS WITH GREASE FITTINGS FRONT AND REAR - NO SQUEEKING!
TUBULAR CONSTRUCTION SAVES WEIGHT WITHOUT SACRIFICING STRENGTH AND DURABILTY
twistedimages
Sep 19, 2024 04:13 AM
silence2-38554
Nov 12, 2015 09:39 AM
Kahnfucious
Aug 15, 2015 08:43 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
