Drivetrain Intercooler for R56
#26
http://autospeed.drive.com.au/cms/article.html?&A=0527
I used a similar set up as this controller on the IC sprayer installed on my old STi. An effective IC sprayer kit would work very well in hot weather, be pretty cheap and still be useful if you upgraded the IC later. A well set up IC sprayer is a pretty good alternative to a FMIC upgrade if you don't want the bling of a huge core. The Mini has a big advantage over an STi with a TMIC, in that the Suby IC sits right over the engine and is prone to heat soak. I'm not sure where the R56 IC is, but it appears to be in the front bumper area, similar to the old 2.7T Audi's. The sprayer will be very effective if that is the case.
#29
#34
how much clearance is there between the stock IC and the exhaust coming off the turbo because first off space will get really tight and you're gonna have massive heat soak if you get too close to the turbo, therefore mostly defeating the point...i was thinking of making a homebrew CO2 IC spray kit and seeing how that turned out...
--E
--E
#35
Link to our FMIC Diverter w/ Sprayers
There you go! Good Luck controlling your mod MADNESS!
(we have pics, a graph, and a video)
http://www.mini-madness.com/index.as...ROD&ProdID=295
Tristan w/ www.Mini-Madness.com
#36
Not many 'gearheads'. Speak for yourself. Check out my gallery & you will see i raced a very serious STI for years fitted with a FMIC among many other mods & it made a huge difference. As for the idea of swapping a front mount to a top mount, that is about the most stupid suggestion i have heard yet. The only reason for ANY forced induction car to run a top mount is packaging requirements & cost saving. Oh & my STI came with a factory water sprayer & it made stuff all difference. You really do need to do some research.
#37
I have to say that I still think that a tmic is not a "stupid suggestion" as you put it. If you have noticed, the R56 has not only the turbo right next to it but the exhaust manifold. Heat soak maybe? Also its funny that the wrc subie cars have a reveresed intake to place the intercooler at the top grill. A hybrid of a tmic and a fmic. So the whole tmic idea cant be that "stupid". There are a lot of subie owners that do go with a tmic instead of a fmic (me for example) that can cause it to have less heat soak with a tmic than with fmic, plus without the lag. Case in point, making it more efficient. As for the scoop not diverting the air to the intercooler as much Dealing with autox you want as much low end power as possible so my idea of eliminating turbo lag by the means of a tmic, I think would be a great advantage. I have done my own research conducted on my 05 wrx (turboxs tmic) and a friends 04 wrx (turboxs fmic) including as many variables that we could keep constant and the tmic was the a few degrees cooler with my mods to the tmic. Excuse me for not sticking with the norm and trying to make my car run better and faster by conducting my own experiments.
#38
There is hardly any piping with the stock MCS front mount, Turbo to intercooler is probably 3 feet if that, and back to the tb is another 5? maybe? You'd cut down a foot or two with a tmic probably, and you could do a top mount on this car, but i'd enjoy seeing your hood afterward. I'm a fan of fmic vs. tmic, heat soak on tmic IS an issue, the motor is right below it. A proper front mount does fine without 90 miles of piping, and if memory serves the APS front mounts are pretty damn efficient with little loss on subies. The hood scoop on the STIs is HUUUGE compared to the mini. Also the WRC subie drivers hit things a lot, a front mount would leak when cracked and there you go, you have no boost. I think thats the underlying reason. Front mount is the way to go, top mounts are only good if you crash a lot (not to mention the surface area difference and velocity of air, etc. of a front mount. Top mounts suck)
My $.02,
Josh
My $.02,
Josh
#39
#40
^^ Isnt debate and exchanging facts (forums in general) a part of improving your knowledge and your car? Because just following what everyone else is saying isnt good enough you need to break the barriers and get out of your comfort zone. Ask questions, debate a few things, stand by your opinions. Isnt that how you learn things? If you dont like it, shouldnt you just not read this thread?
#41
#42
I'm reading the thread hoping to pick up information on new intercoolers for the Mini Cooper S, not how someone's opinion is stupid, and not about how empirical data taken on a Subaru should be presented as fact for a MINI.
I've got a bigger top mount, I know the shortcomings of the design. Only reason I don't have a front mount on my WRX is because it's expensive and I'm lazy.
So..... any new intercoolers for the MCS?
#43
#44
Ive even gone to the extreme of adding 3x 4 inch high performance ball bearing computer fans to my ic diverter for my tmic to help the ic breathe better and to bring in a larger volume of air. Then I have a relay that switches (manually) the fans on at a stoplight or resting point on the track to extract heat (b/c it is easier to extract heat from an object to have faster cool-down) from the ic. I just made this so I havent gotten the chance to test it out yet. Along with a perforated screen on the scoop to catch most of the water incase of rain, I feel that this would help the ic with cooler air. This is what I like to do rather than just pop on an upgrade and be done with it.
#45
Fans on ICs
are good things! They're pretty common in the Mustang world where there's no easy way to get cooling air for a conventional IC to the centripital SCs that are available from many for the V8s. With the computer fans, make sure they can flow enough, and that they'll take the heat of the underhood envornment. Nothing worse than melted plastic on the valve cover!
Matt
Matt
#46
#48
As far as WRXdrivers suggestion, I agree that the engine layout of the Mini would make a TMIC a less than ideal solution, but you really don't have to use the word "stupid" in your response, he was just throwing ideas out there.
A Mini Maddness diverter/nozzles and the autospeed controller would be a very good setup with or without an upgraded core.
IQRaceworks
07-15-2022 05:51 AM
08-11-2015 09:01 AM
Ambient Thermal Management
08-07-2015 12:27 PM
