Drivetrain Which Sway Bars
Old Jul 7, 2007 | 05:08 AM
TobiasMWesten's Avatar
TobiasMWesten
Which Sway Bars
Im looking to install a rear sway bar on my 05 cooper S. I heard that HR are supposed to be the best in quality. but i didnt see anything thicker than 19mm. any recommendations on wich sway bars to get. i was thinking about 21mm ish.
thanks
Old Jul 7, 2007 | 05:42 AM
minimarks's Avatar
minimarks
H-Sport, wide variety of sizes and great quality...
Old Jul 7, 2007 | 09:28 AM
Crashton's Avatar
Crashton
I'm running the H-Sport 19mm rear bar. They also make a 22mm bar. IMO the quality is top notch.
Old Jul 7, 2007 | 09:50 AM
MOTORN's Avatar
MOTORN
Anti-roll bar
Actually, H-Sport has 3 different rear bars.
Call Chad @ Detroit Tuned and he will help you out.
586 296-6001
Old Jul 7, 2007 | 10:01 AM
Crashton's Avatar
Crashton
My bad.... You are correct, I believe that they also have a 25mm bar.
Old Jul 7, 2007 | 11:11 AM
#20Works4me's Avatar
#20Works4me
Don't be caught in the trap of "bigger is better" you need to consider the type of driving you are doing, bigger bars are better for track etc but not necessarily for the street or daily driver. Squeaking is also an issue. The 19mm H&R as no squeaking issues. H-sport is also a good brand. Good luck.
Old Jul 9, 2007 | 10:13 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I have H-sport front(27mm) and rear(19mm) The front is set on soft and the rear is set in the middle(3 settings). I love them. If I ever do anything different it will probably be the Alta 22mm rear bar.
Old Jul 9, 2007 | 10:38 AM
YakiMini's Avatar
YakiMini
I recommend the Mini-Madness.com 22mm Adjustable FORGED SB. I don't know how many people are familiar with Forged Equipment but it is a one piece bar with no wields so it is stronger.
Old Jul 9, 2007 | 11:28 AM
irieman's Avatar
irieman
yeah- what he said. (emphasis added) personally, after careful thought and research i chose the 19mm rear sway bar from h-sport. yeah i'm kidding. it was a great deal i couldn't pass up! but i couldn't be more satisfied. now that i'm used to it, i'm considering switching that up from the "low" setting to
"middle". and see what that does.
Old Jul 9, 2007 | 12:46 PM
leapfrog's Avatar
leapfrog
Rear Anti-Sway Bars...
My wife bought me a 22mm rear bar(Progress) from Moss,which has 2 adjusting holes.The one setting made for a stiffer ride/better bite,so after a few weeks I switched to the softer setting,which is more comfortable on the pot-holed roads I have to drive on every day.This bar comes with 2 new brackets which don't have grease fittings,only a small tube of grease.After 2 months,the grease is gone,and faint squeak can be heard.I'll probably remove the brackets to install grease fittings.You may want to get info on the brackets supplied,and the type of grease they recommend.
Old Jul 9, 2007 | 12:49 PM
mozzarella's Avatar
mozzarella
thanks
Ask yourself why do you want a bigger RSB when you have the answer to that it will go a long way to what bar to buy.
Old Jul 9, 2007 | 01:00 PM
SharoSC02's Avatar
SharoSC02
hotchkis is also a very good brand. I have them on my car and they are 2 thumbs up.
Old Jul 9, 2007 | 01:05 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Love my H-Sport 19mm. I do NOT track it (it's a cabrio with an auto) but I drive the HECK outta it on the Dragon. USS plus 19mm H-Sport on middle setting makes the car neutral and very responsive, but with no bad manners in daily driving.
YaTuSabe
Aug 23, 2018 11:41 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
mauiguyharry
Oct 8, 2015 06:53 PM
