Drivetrain New Engine Install
Old Jun 22, 2007 | 03:51 PM
oneM1KE's Avatar
oneM1KE
New Engine Install
Hey everyone! I recently had a spun bearing in my engine. I had a new engine installed (new clutch and supercharger also), thanks to my dealership, and just had a few questions.
Since I have a new long block in my car, I am aware that the mileage count is set to zero. With that said, should i take the same break in process as I would with a brand new mini?
Are there other things i should be looking at as far as repairs/maintenance.. like fluids and other parts that arent technically new?
Any advice would be great.. Thanks again!!
-mike
Old Jun 22, 2007 | 03:54 PM
mozzarella's Avatar
mozzarella
Break it in like a new car.
Old Jun 27, 2007 | 04:41 PM
SteveS's Avatar
SteveS
How many miles on the car? Any idea which bearing and why it "spun"?
Old Jun 27, 2007 | 04:47 PM
Eric_Rowland's Avatar
Eric_Rowland
New SC on your dime or MINI's? If the latter, why?
Old Jul 6, 2007 | 08:48 PM
wrxdriver's Avatar
wrxdriver
Break in the engine and reset your ecu. You can reset your ecu by simply pressing down on the brake pedal while your neg. is disconnected from the batt. The odometer (or any readout on your dash) will fade away untill you reconnect your batt. Resetting the ecu re-calibrates the ecu to the new engine (or any engine mods) and allows for easier exceptance to the change and can even make the engine perform better (even after mods).
Old Jul 7, 2007 | 06:46 AM
PaulCIssa's Avatar
PaulCIssa
Hey Mike! Congratulations. I've followed your experience and think in the end, you did all right. The lessons learned should be burned in your mind for a lifetime.
Stock up on oil filters and oil since they're consumables. Use them often and in good health.
All the advice is spot-on: break it in like a new engine, because it is! Also make it you're business to check for any wetness on the engine each time you pull the dipstick in case any leaks develop. More oil is better than less, so keep it topped up.
Best of luck with your new powerplant!
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
