Drivetrain Are the later and lighter OEM crank pulleys worth fitting?
Old May 6, 2007 | 05:51 AM
fozworth's Avatar
fozworth
I already have a lightend flywheel and didnt want to fit a after market crank pulley as well due to possible bottom end wear /vibrations.But i understand the later 05 onwards oem crank pulleys are lighter so are they worth fitting.And will they help with a quicker rpm pick up.
Old May 6, 2007 | 06:26 AM
Alex5's Avatar
Alex5
Had the latest one fitted by Mini this year when the original early one failed.
I didn't know the unit was supposed to give an improvement and certainly didn't notice anything after it was changed.
Old May 6, 2007 | 08:30 AM
Bster's Avatar
Bster
If your old one hasn't failed yet, then I would just carry on using it. I bought the newer version and it didn't come cheap!!
Old May 6, 2007 | 10:36 AM
Guest's Avatar
Guest
Yea, i'm not sure the cost justifies the performance increase. You'll have better luck with a flywheel if you're looking for throttle response.
Toolman
Jan 20, 2016 06:50 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Lt. Dan
Aug 10, 2015 12:46 PM
