Getting a buffer, need pointers
I'm getting a new buffer, a porter cable 5 inch.
I now know that I need to get soft buffing pads.
But my main concern is how hard to push down on the tool?
Do I just let tool weight be enough, or do I lean on it some.
I'm just looking at buffing wax.
If doing scratch removal use higher speeds 4-5 and push only "slightly" harder to deform the pad slightly, but basically, the weight of the machine is the rule.
If you push too hard you will bog down the spinning action and only have the "jigging" action. (you want both for full effect) Feel free to experiment with this and you will see what I mean. It doesn't hurt anything, the tool has a clutch.
I love my Porter-Cable!!! Most of the time it's best to let the weight of the machine do the work. The only time I exert any pressure is when using a mild abrasive to remove scratches. If that doesn't work I switch to a coarser grit rather than leaning on it. Keep a good grip on the orbital. A couple of times while shifting position I let the handle dip down and put a minor scratch in my paint!
BTW, I gave up on the wax thing and am trying Griot's Paint Sealer going into this winter. Waxes never last past the first couple of snow storms. I was a little concerned about the look of sealer, but I applied it with the PC orbital and Nugget looks every bit as good as when he has fresh wax. Time will tell.
Pete
Pete
just got an email, Autopia is running a deal that gets you 20% off their Sonus Polisher Kit which is a Porter Cable 7424. Comes with some pads too. So it's $160 before shipping.
I've been debating picking up a DA polisher for a while. This might be the thing that pushes me over the edge.
Yup, I got the email, too. Consider me pushed over the edge.
Can we get more tips and tricks for us newbs?
I used to be religiously agaisnt using a machine polisher, but I want to start doing other people's cars for money, and I know the time saved will help a lot.
mb
mb
mb
mb
Kimolaoha
Jul 5, 2023 01:04 PM
atenzany62
Aug 26, 2015 09:26 AM
