Ran Over Paint
Old May 22, 2018 | 09:41 AM
BluGnat's Avatar
BluGnat
Ran Over Paint
On my way to work today, I evidently ran over spilled paint on the highway. It's a light grey, so it looked like a weird wet spot on the lane - but when I drove through it (sadly, couldn't avoid it), it was extremely slippery. When I got to work, I have paint all over my tires, and of course the spray from the tires on the car. I tried to lick a finger and wipe it off - no dice. My husband said he can goof off/clay bar it off. I wanted to check in to see if anyone has any good advice on products/methods for fixing this sort of super upsetting paint ordeal? It's my understanding that MINI paint can be delicate? Thanks in advance for any advice.
Old May 22, 2018 | 10:29 AM
Whine not Walnuts's Avatar
Whine not Walnuts
The BMW top clear coat is extremely hard according to many paintless repair folks I have talked with. If the paint you rain over was latex based you should be able to get if off with out doing damage to your car.
Old May 22, 2018 | 11:42 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
yeah, clay bar with a lot of lubricant so it won't stick or get a polish that removes scratches and blems to remove it.
Both ways you will need to follow up with a coat of wax
Old May 29, 2018 | 02:22 PM
Capt_bj's Avatar
Capt_bj
hubby probably already knows but some experimenting to determine what kind of paint it is will help find the right solution
if it was 'house paint' like a latex there are special paint removers available but goo-gone, goof-off and even WD-40 will probably melt it and won't harm the clear/paint .... follow by cleaning all the solvent off and then re-wax.
Problems can develop if it is NOT latex and these known solvents don't work. Pure mineral spirits can be used but don't let them sit on the paint any longer than necessary as this WILL eventually soften the clear.
If this paint was in fact a primer your problem could be more severe.
Clay or rubbing compound can remove any of the above BUT remember even clay is an abrasive .... which means you are removing something .... in this case the bad paint but ALSO good clear. You might consider engaging the services of an experienced/trusted detailer because full of buffing could be required in a worst case ....
and we have not discussed paint on plastic trim like wheel wells yet ....
I accidentally ran thru fresh yellow road stripes once and it splashed up the side of the car .... fortunately was on my way home and had a can of 'spirits' in the garage.
Old May 29, 2018 | 07:15 PM
dube53's Avatar
dube53
Simply lighter fluid. No damage to the clear coat.
Prost
R55 :: Clubman Talk (2008+)
21
Apr 10, 2009 09:48 PM
lacning74
May 12, 2008 01:46 PM
sbgobig
Tires, Wheels, & Brakes
18
May 26, 2004 02:43 PM
aziandoll
Southern California
Oct 26, 2003 02:11 AM
Styjan
Oct 6, 2003 02:06 PM
