How To Clean a Black Fender Trim......
Old 06-06-2018, 06:27 PM
dube53's Avatar
dube53
dube53 is offline
Originally Posted by bratling
So… is this effect exclusive to peanut oil? Would any old vegetable oil do the job? Or is there something special about peanuts? hmmmm.
LOL.............. I graduated to something else after the peanut butter experience. This was not conclusive and fortunately, it was a test on just one flare during last winter.
Shoe polish after deep cleaning worked the best for me. They stay satin black and water spot free after every week wash in the last 3 months and my car is outdoor all the time.
The following 2 users liked this post by dube53:
bratling (06-02-2019), MiniTigger (06-06-2018)
  #52
Old 06-06-2018, 06:48 PM
Dave.O's Avatar
Dave.O
Dave.O is offline
Originally Posted by dube53
Interesting.............. and you remove all the trim. I am impressed.
Can you share how you clean glass to remove water spots and wiper gripping?
Glass cleaning is simple. Gyeon water spot remover $13.99 and 0000 steel wool.
0000 steel wool will not scratch the glass at all and I have been using it for well over 20 years.
https://www.esotericcarcare.com/gyeon-q2m-waterspot/
Also always wipe Up and Down on the outside glass and and Side to Side on inside glass. This way you always know what side of the glass a small streak is on. I also always use two towels, one wet with glass cleaner to remove dirt and oil clean glass. The second towel is always a dry lint free towel to remove any light streaking, polish the glass and final wipe.
The following 2 users liked this post by Dave.O:
Goldsmithy (06-13-2018), MiniTigger (06-06-2018)
  #53
Old 06-06-2018, 07:24 PM
dube53's Avatar
dube53
dube53 is offline
Steel wool makes sense and maybe just what I need to remove very light water stains from my front and back windshields.
But, I will pass on your Gyeon recommendation since you may be aware it destroys hydrophobic properties of coatings.
Do you have any other suggestions?
  #54
Old 06-06-2018, 08:25 PM
Dave.O's Avatar
Dave.O
Dave.O is offline
I only use it on glass for water spots.
For removing water spots off of paint I just wipe the paint with a light finishing polish on a white pad by hand or a MF towel to remove the spots and not destroy the coating under it. Then use CarPro ReLoad to top the coating off again to keep the hydrophobic properties.
  #55
Old 06-07-2018, 08:44 AM
Dave.O's Avatar
Dave.O
Dave.O is offline
FYI about Gyeon water spot
The biggest advantage of Q2M WaterSpot is its complete safety for paint and most of all - coatings. Due to inappropriate maintenance, water spots may become an issue on fresh coatings, but owning to product’s properties, Q2M WaterSpot does not affect or damage the coating. You can therefore remove the most undesirable defects by using O2M WaterSpot without needing to polish and re-apply the quartz coat.
Q2M Waterspot is very easy to use. Before applying, clean the bodywork with a HQ, gentle, pH-neutral shampoo and dry the surface. Than spray directly onto the paint or on a microfiber cloth and wipe the area affected with water spots. If having strong staining, spray generously directly onto the surface, leave for a couple of minutes and then wipe such surface few times with a MF.
Q2M WaterSpot is thick and oily, so very little product is required to cover a large area. It does not diminish or dry fast, so the cleaned area can be wiped multiple times.
  #56
Old 06-07-2018, 10:20 AM
RudeJoe's Avatar
RudeJoe
RudeJoe is offline
Want to share how you detail a convertible top? The one on the red MINI above looks great.
Sure wish you were in my area.
  #57
Old 06-07-2018, 10:43 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
I'm curious to see if any of you guys have tried 303 Aerospace Protectant? I've used it on the rubber and plastic trim pieces on some of my cars and it works great. Leaves a shiny matte appearance behind and seems to recondition the pieces.
888.280.7799 | 6am - 5pm PST
  #58
Old 06-07-2018, 01:12 PM
crazy4trains's Avatar
crazy4trains
crazy4trains is offline
303 comes highly recommended. I've been using it for a short period of time so I can't give any discussion on long term performance but I do like it so far.
  #59
Old 06-12-2018, 05:27 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Following up: this past weekend I was cleaning (more of) my spouse's 2014 Countryman. There was both polish and wax residue on the trim, (because I was sloppy).
I went to the kitchen. We were out of corn oil so, taking advantage of the fact she was out, I grabbed the safflower oil and a paper towel.
Holy moly does that work like a charm! I'll want to see how it lasts through the summer, but if it lasts even a few months then it's better than any "Back to Black" or "Black Wow" type product I've tried.
I tentatively assume that any clear vegetable oil will do the job. (I didn't want to use olive oil due to its stronger scent. Besides, the car is German-English, not Italian...)
  #60
Old 06-12-2018, 05:47 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Thinking that Penetrol is basically boiled linseed oil. The key is that it will get hard and therefore will not collect dust. Somebody might be able to chime in on what the perm rating is of plastic but thinking it is less than 0.1 that means there is not too much that is going to penetrate it to make any real difference.
  #61
Old 06-12-2018, 08:59 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Can't wait to hear if the neighborhood dogs are licking the Safflower oil off your car. What a tasty MINI you have!
I see Naphtha as the major ingredient in Penetrol.
  #62
Old 06-13-2018, 03:37 AM
Whine not Walnuts
On Pentrol, appears the working part is a coconut product, cocamide diethanolamide that is made by combining coconut fat with diethanolamine that is a type of rust inhibitor product. Naptha is a type of mineral spirit type product but many associate this particular type with "white gas" or Coleman lantern fuel.
Whatever it is, it does work on black trim quite well.
  #63
Old 06-13-2018, 06:06 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
bratling (06-13-2018)
  #64
Old 06-15-2018, 08:23 PM
ssean72's Avatar
ssean72
ssean72 is offline
I know this isn’t what you are looking for but I got tired of messing with the black trim so I had very thing painted body color except the parts under the doors. I spent a long time smoothing all the trim before paint even the parts I left black. The black bits I left black I primed sanded and painted with duplicolor black trim paint, the body color bits I sanded down and let my dodgy guy finish those. They came out great and don’t have to mess with cleaning them any special way. Just figured I would though that option out there.
Attached Thumbnails How To Clean a Black Fender Trim......-9ef419a3-d7b5-420c-aa75-5e5e163381c1.jpeg   How To Clean a Black Fender Trim......-a9215d5e-c7b3-450d-a094-58043c63b91a.jpeg   How To Clean a Black Fender Trim......-5dd01ef4-3808-4c17-8950-6fe255417c2f.jpeg   How To Clean a Black Fender Trim......-0d9c2f3b-a72e-4ccc-bc2a-1247cf593795.jpeg   How To Clean a Black Fender Trim......-1857fb98-ae5c-407e-8793-f351cca90df7.jpeg
The following 3 users liked this post by ssean72:
Bikeboy2018 (10-31-2022), bratling (06-02-2019), Minnie.the.Moocher (06-15-2018)
  #65
Old 06-15-2018, 10:54 PM
Minnie.the.Moocher
Looks great! My least liked feature of the MINI looks is the plastic parts.
  #66
Old 06-16-2018, 04:37 AM
Whine not Walnuts
Yes, this is another option.
Car looks great by the way.
  #67
Old 06-16-2018, 05:00 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
gorgeous! I actually dig the contrast the black trim provides on light colored minis, but I have to admit that the consolidated color scheme you’ve created really looks great. And that blue and silver combo… swoon!
  #68
Old 06-16-2018, 05:08 PM
ssean72's Avatar
ssean72
ssean72 is offline
Thanks for the nice comments, I have put allot into her over the past year, she is a Checkmate so the silver is factory, I wanted to do something different.
  #69
Old 10-16-2018, 07:24 AM
TnickR57's Avatar
TnickR57
TnickR57 is offline
Plastic trim what he's doing is talking to a dog
I use to keep them nice and shiny with Meguiars Black Plastic detailer.
Now, I have one getting stained from rain with a white chalky deposit. How do you clean them?
i use Wipe New. Lasts a little Ng time. Don't get it on the paint!
  #70
Old 10-16-2018, 07:26 AM
TnickR57's Avatar
TnickR57
TnickR57 is offline
Don't know how that talking to a dog part got in there. I just typed in plastic trim! And it lasts a long time
  #71
Old 03-03-2019, 10:35 AM
shrevemini's Avatar
shrevemini
shrevemini is offline
I just replaced the trim. Not that expensive. Not hard to do. Mine was looking horrible. She going on 15y. Getting her ready for the MOTD in may.
  #72
Old 03-04-2019, 06:27 AM
Yep, most people do that if the trim is long gone and/or damaged of cut up from rocks.
  #73
Old 05-13-2019, 07:15 AM
AndyJM's Avatar
AndyJM
AndyJM is offline
I've been using Chemical Guys "Bare Bones" undercarriage spray. So far it has done the best job of maintaining the black trim, and it doesn't wash off with every car wash. It also doesn't leave any greasy residue and is fantastic for keeping the wheel well liners looking sharp.
  #74
Old 05-28-2019, 04:08 PM
TheBigNewt's Avatar
TheBigNewt
TheBigNewt is offline
Water will remove wax from plastic trim you just have to use a pressure washer with a fan tip. Then lightly wipe all the trim with acetone to remove all silicone dressings. Once the trim is clean you can coat it with a ceramic coating and it will last for years without any discoloration or spotting.
You don’t want to use silicone based products or black tinted products to protect trim as they all fail and will wash away.
What's an easy to use ceramic coating for the trim? I've only used Black Wow which is "OK" but leaves a lot to be desired wrt how uneven it looks after application.
  #75
Old 06-21-2019, 11:07 AM
TnickR57's Avatar
TnickR57
TnickR57 is offline
Black fender trim
Wipe New works for me. Don't get it on the paint!
Quick Reply: How To Clean a Black Fender Trim......
