Salt stains
Old Jun 4, 2015 | 07:35 PM
Csbdr's Avatar
Csbdr
Salt stains
Hey! I was wondering what everyone would recommend for removing salt stains from carpet. I originally thought "it's salt, water will just dissolve it" and that mostly worked but I can still see stains on the black carpet from winter. I had the MINI rubber floor mats in and they just weren't adequate for keeping all the crud from seeping off the edges onto the carpeting. The guys at NAPA didn't have any suggestions other than "touch it up with black spray paint." I'm not that desperate.....
Old Jun 4, 2015 | 08:21 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I'd try an oxygen based spray, I use some from home depot, Zep brand. Keep in mind that road salting is no longer just salt, but often a mix of chemicals, deicers. Good luck!
Old Jun 5, 2015 | 04:00 AM
ShipM8's Avatar
ShipM8
I have one of those little Bissell's that does a pretty good job. Be generous when blasting the carpet cleaner and rub it around before sucking it up. You'll need to vacuum after the carpet dries.
Old Jun 29, 2015 | 03:44 AM
r7denz's Avatar
r7denz
Try to remove most of the salt while it is dry using a stiff brush and vacuum. Then use Folex.
gsredmini
Oct 20, 2015 07:43 AM
phrza81
Oct 10, 2015 11:37 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
Powershift
Aug 16, 2015 05:14 PM
