VERY rough body surface
Old Oct 11, 2012 | 11:21 AM
AYEBOY's Avatar
AYEBOY
So after picking up our MCS from a previous owner, we quickly realized that its likely that the car was probably not regularly washed and detailed. As a result there is a lot of buildup and grime on certain surfaces that do not come off with a regular wash... particularly on the trunk/bumper area. What is the best way to get rid of this and get the surfaces back to that smooth showroom condition? Not sure I want to take it to a detailer just yet in fear of messing it up completely. Thanks!!
Old Oct 11, 2012 | 11:46 AM
jibber11's Avatar
jibber11
Easiest DIY to start with would be clay bar it.
Go to any auto parts store and pick up a kit, it works wonders and is kinda tough to screw up.
You'll need to re-polish/re-wax it afterwards.
Old Oct 11, 2012 | 02:15 PM
Capt_bj's Avatar
Capt_bj
hmmmm, not sure I follow this logic ... a good detailer should be the guru to ensure you don't mess it up.
But if you want to DIY, concur that a clay bar is probably the right place to start. I'd give a good wash with DAWN first, this should remove any old wax and there's no use in clogging up a clay bar with old wax. THEN use the clay according to directions on the package. If you don't have enuf lube spray, just use detailer spray or soapy water - made with an auto wash soap tho. The clay SHOULD bring the finish to a good smooth . . if not, you probably want to find a good detail guy, but ask around to ensure you find a good one. He'll probably need to go to a rubbing compound and a buffer, or that's what I'd do anyway, and this CAN screw things up in the wrong hands.
My bet is clay will solve your problem tho unless what's on the car is paint over spray or something like that.
btw - you can do a 6 inch square section and decide if it working or a waste of time b4 investing more time . . .
brand of clay doesn't really matter. You'll usually find Meguires and/or Mother's at decent auto part stores. Technically, you can go to a craft store and get kids modeling clay and just use soapy water as the lube. That usually costs 1/10th what the auto part store package does!
Old Oct 11, 2012 | 02:32 PM
fenderless 33's Avatar
fenderless 33
Amen to the cost Capt. I pick mine up at street rod meets. Mothers kit was 19.95 at O'Realy's and I can get them for 700 to 8.00 at most meets. Ayeboy could also try compund by had if not used to a buffer.
Old Oct 11, 2012 | 02:48 PM
Fly'n Brick's Avatar
Fly'n Brick
If clay bar sounds too intimidating, go visit Richard aka octaneguy here on NAM for a video demo on using clay. It is easy to do and makes a world of difference.
Old Oct 11, 2012 | 08:30 PM
AYEBOY's Avatar
AYEBOY
thankyousir! will give it a try.
thanks for the tips! I've heard stories abt detailers leaving swirl marks and making things worse.
thanks!! will try the clay. Using polishing compound is almost an art that I don't have the time to perfect!
thanks dude! vids always help!!
Old Oct 12, 2012 | 07:59 AM
OctaneGuy's Avatar
OctaneGuy
Thanks! Here is a video I made on using claybar.
Old Oct 18, 2012 | 08:44 PM
AYEBOY's Avatar
AYEBOY
Thanks Richard!! Will need to get me some clay.
jeri534
Nov 6, 2015 01:40 PM
minieater
Oct 28, 2015 02:15 PM
krohm
Sep 28, 2015 12:16 PM
Sep 25, 2015 12:32 PM
daviday
Sep 25, 2015 01:31 AM
