Need help with clear coat
Old Aug 22, 2012 | 08:01 PM
randall-tyr's Avatar
randall-tyr
I was trying to repair some scratches myself and have made a mess of things. First off it seems I sanded to hard and went through the clear coat so I then went to the store for help and was given a clear coat spray and after using it of course it does not match. so now I have spots all over the car with a miss matched clear coat. Before I go ahead and screw this up anymore I am wondering if anyone has some advise? I am thinking the whole car is gonna need to be sanded down and a clear coat re-applied. The clear coat that I sprayed on was supposed to be high gloss but it looks like a matte finish and when I try to sand the edge to blend it just sands off the original finish. So frustrated. Thanks to anyone who can give some words of encouragement or help.
Old Aug 22, 2012 | 10:51 PM
Fly'n Brick's Avatar
Fly'n Brick
I've started and deleted 4 different responses to this and still don't know what to say except to say quit making it any worse. Based on your description, a good body shop is your only alternative now.
Old Aug 23, 2012 | 07:24 AM
axleR56's Avatar
axleR56
you did what?
I would take it to a body shop before you make it worse. Not going to be a cheap repair i would assume.
Old Aug 23, 2012 | 07:43 AM
mini44's Avatar
mini44
Wet sanding takes practice. I think I'd stop practicing on the MINI. Have you polished it yet? That can make it look a lot better.
Old Aug 23, 2012 | 08:01 AM
ACEkraut11's Avatar
ACEkraut11
Pics would help a ton. But from your description sanding does not seem to be one of your best attributes. What grit are you using for sand paper? Are you wet sanding? Are you using a block? Have you spent some time on youtube.com to find a video or two to show you what you should be doing? Do you have a random orbital polisher, compounds, etc.?
Old Aug 23, 2012 | 04:10 PM
fenderless 33's Avatar
fenderless 33
Randall: It sounds to me like you have F*cked up big time. I have painted a number of street rods and if you think you can pull this off and want to call me I am at 850-496-5336. Hope thisw helps.
navybsn
Oct 5, 2018 04:42 PM
OutMotoring
Mar 3, 2017 06:29 AM
vetsvette
Oct 11, 2015 06:05 PM
navybsn
Oct 4, 2015 03:27 PM
potterstein
Oct 1, 2015 07:10 AM
