Acetone on Windshield?
Old Jul 29, 2009 | 07:13 AM
bakerjam's Avatar
bakerjam
I have RainX on my windshield and would like to remove it. Will acetone work? It's supposed to be great from removing thin 'films' and I don't want to damage my windshield. Thanks.
Old Jul 29, 2009 | 08:34 AM
lotsie's Avatar
lotsie
Seems a bit extreme. Try vinegar, or alcohol mixed 50/50 with water.
Mark
Old Jul 29, 2009 | 09:03 AM
kenchan's Avatar
kenchan
+1 on the rubbing alcohol. use alcohol (I use 70%) or Griot's PaintPrep.
actually Griot's WindowCleaner will also remove it. it has higher alcohol content vs Clarity (my guess per evaporating speed)
Old Jul 29, 2009 | 12:26 PM
MLPearson79's Avatar
MLPearson79
Acetone *would* work but I'd go another route as well. It'll eat right through your paint if you drip or spill - I use it to remove nail polish easily!
Old Jul 29, 2009 | 12:47 PM
kenchan's Avatar
kenchan
plus it could dry out the seals if you get them on the edges of the glass.
Old Jul 29, 2009 | 09:32 PM
lotsie's Avatar
lotsie
Lets not forget you need thick rubber gloves if you work with acetone. It does bad things to humans.
Mark
Old Jul 30, 2009 | 10:22 AM
Prima Car Care's Avatar
Prima Car Care
Mark
Although acetone won't harm glass, I agree that it seems a little harsh. I also suggest mixing rubbing alcohol (standard stuff from your local drugstore) and water, 50/50. That should do the trick and is less harsh.
Actually, FYI... Prima Clarity does not contain any alcohol at all.
-Heather
Old Jul 30, 2009 | 11:09 AM
kenchan's Avatar
kenchan
-Heather
how the heck did you do it???
Old Jul 30, 2009 | 11:48 AM
RckyMtnTwisties's Avatar
RckyMtnTwisties
Acetone will leave steaks on your glass, which you will have to remove with something else.
Old Jul 30, 2009 | 12:20 PM
lotsie's Avatar
lotsie
Are those steaks medium rare? I like mine that way.
Mark
Old Jul 30, 2009 | 12:24 PM
bakerjam's Avatar
bakerjam
Would Windex would remove them? I'm concerned with damaging the glass by using acetone more than anything.
Old Jul 30, 2009 | 12:34 PM
lotsie's Avatar
lotsie
Rubbing alcohol
Mark
Old Jul 30, 2009 | 02:01 PM
kenchan's Avatar
kenchan
windex actually leaves behind residue... and belongs in the stove/counter top/kitchen sink cleaning basket.
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
bahman
Sep 26, 2015 07:38 PM
The Rossness
Sep 17, 2015 03:06 PM
