Glass Cleaner
Embrace your feelings Luke, come to the darkside...
BTW, I'm assuming your microfiber for the paint is in the driver seat back but which cupholder is the quick detailer in?
I have my glass cloth, cleaner, QD, and monster fluffy in an army CLS bag that I keep behind my seat
I had some sort of haze/chemical on my window that was driving me crazy. Last night I clayed, used Clarity, and followed up with a spritz of Hydro. Haze was not only gone but the window repelled water like it does with RainX (except it didn't streak as much with the wipers). I call that a hit. It's also the first time I've seen Clarity live up to the billing. I had been considering going back to Stoners (and still might).
OK, new MINI owner here. Had lots of fun the last couple days squashing bugs with my windshield, but now have to clean them off. To make it just a little more complicated, I was forced to travel a dirt road yesterday (no gun to my head, but close). So I have a fair amount of dust to deal with.
I got the Stoners Invisible Glasss (foam). I got a glass microfiber cloth. I tested a small portion of the rear side window. Didn't look good. Felt like maybe I was scratching it but light was getting low so I couldn't tell for sure.
Should I spray the car off first? Am I just not using enough IG? Other ideas?
Thanks.
Thanks.
Testwoods...I think you will want to get the dust off before using the Stoner. If you don't want to go the whole wash route, then try sponging off the dust from the glass, then clean it.
Did you get any Clarity with your DP order?? That works as good as the Stoner Invisable Glass. I use both!!
CLARITY!!!!
I just tried Clarity. It is truly amazing. I honestly had to check if my side window was up at one point -- I could not see the glass. This is the best window cleaner I have ever used!
Amen. Used Invisible Glass for a long time and it works. in fact it works so well that my go-every-where sidekick tests to see if the glass is really there and leaves at least one nose print on the inside glass.
White Viniger and water is best
Just put 1/4 white viniger to warm water for the best glass cleaner you will ever need. If the window is really dirty use crumpled up newspaper to clean it.
Ronnie
Ronnie
Vinegar is very acidic -- might this cause problems?
Thanks! Yes, she has a charger, but in So Cal, she DOES get driven a lot, esp. during this 10 year draught we're having!
One caveat about RainX, if you have a DoD sticker (and maybe other similar stickers), RainX will disolve the ink and you'll have to go get a new one. This includes RainX windscreen washer fluid.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
daidaibi
Mar 21, 2016 08:25 AM
gnhovis
Sep 28, 2015 04:07 AM
Mini ni
Sep 24, 2015 05:42 AM
