OMG! My kids scraped the snow off my 2007 MCS w/ a wood chisel!
Is five years old considered...
to old for late term abortion???
My daughter is 26 and I have been known to threaten her for far less then that. I have a mouse that I sent to "Ratatouille" heaven for chewing on 'Rita's wires!!!
Probably the first step you need to do is decide how deep the scratches really are. If they are only to the clear coat you can probably wet sand and buff out. If they are through the clear coat but not through the base or color coat then you can probably GENTLY wet sand around the scratches that are down to the color coat(being very, very careful to not go through the color coat to the primer), feathering the edges of the scratches, apply some clear coat, wet sand again, then buff to a nice shine. If they are through to the primer you can try to wet sand down to nice feathered edges, get some paint in your color, mask and paint, wet sand, repeat as necessary until a good color match is found, clear coat, wet sand, repeat as necessary, then buff out. If right about now you are thinking that you would be nuts to try this yourself, ignore everything above and find a good body shop to quote you a price and have them do it. If you are still interested in pursuing things from here I can give you the specific details on what worked for me when I did some work on my 71 Triumph TR6 this summer after an SUV backed out and turned the bumper into my parked car.
afxok,
I did some checking on this and we (State Farm), under our policy, would cover your damages under your Comprehensive coverage.
Check with your insurance company and see if they will do the same.
I realized pretty quick that's what I needed to do. Otherwise it would still be eating at me. MINI still motors so life's too short to dwell on it. Our family does more fun things these days because it's fun to get there! That's the important part.
Are there any risks with getting a mismatched finish? I've never had any body issues on any of my previous vehicles so I'm not sure what to expect. It just seems overkill since MINI is only 6mo. old!
You all will probably be able to give me a better idea on that once I get a picture up (still -10 degrees today and I'm afraid to wash it).
Unless you let your kids paint it
, no chance of paint mis-match.
Even on cars that are old and faded, a good paint man can match it and blend it in a way that you would never know it was painted. So on a 6-month old car with paint in good condition, piece of cake for them !
Yeah, I hope the repair is cheap and you don't need your policy. But in the event you do, always nice to know it is covered.
Good luck.
, no chance of paint mis-match. Even on cars that are old and faded, a good paint man can match it and blend it in a way that you would never know it was painted. So on a 6-month old car with paint in good condition, piece of cake for them !
Good luck.
.Going off topic here, but at least the kids still fit. I sized them both up at the dealer before I bought it. Since then, I've had other MINI owners spy both of my booster seats in the back and say "You mean you didn't have to get rid of the MINI when you had the kids?" Nope, the kids came first!
--Tony
I feel your pain.
Good advice here - now's the time to justify buying a a Porter Cable polisher...
I think I was five when I 'helped mommy' by pounding a nail through our linoleum floor.:impatient
Sounds like you've got a good perspective.
Another alternative - Don't repair the damage, and use it as psychological blackmail as they get older and can understand what they did!
Pretty funny thread here. I missed what color your MCS is? Btw, I don't think the 2007's have a primer coat.
I can also spot a repaint. Usually the tell tale signs are in the edges--did the trim get removed or did they mask up to the edge. Was the repainted area colorsanded? If so, was it done too well where there is no orange peel while the rest of the car has orange peel? Did they color sand in areas that you can't buff so they left sanding marks behind? When they painted the panel, did they remove the existing paint or just paint over it? My electronic thickness gauge would tell me.
On metallics, I can spot blending lines--where the painter tried to feather the edge back into the paint instead of stopping at a panel line or wrapping it around an edge.
Depending on the severity of the damage, a PC may not have enough muscle to correct severe paint damage.
Some MINIs are repainted days old without your knowledge before you pick it up, lol. Overkill? No. Are there risks? Always. Whatever body shop you use, make sure they will redo the job to your satisfaction. Inspect the job under bright sunlight--don't have any cause of the snow? Take a set of 500 watt halogen work lamps with you. If that's too bulky, get the brightest Xenon or LED flashlight you can find and point it at the finish and inspect it very closely looking at where they painted it. Outside under sunlight from different angles is where you will see whether the paint matches.
+2 on the pix!
+2 on the pix!
Okay, Richard... some of those points you made are the difference between a good paint man and a great paint man.
And if you have to whip out your guage to measure thickness to determine if a body part was repainted, it was a very good piece of body work !
I know your heart sank...but inside I did laugh a little - sorry...
Little kiddos are so innocent at that age and they just wanted to help. I can only imagine how you must of felt...
Do I scream??? Do I yell??? Do I calmly take hold of the situation??? Ugggg.....
I know your MINI will be fixed as good as new soon.
Donna
Do I scream??? Do I yell??? Do I calmly take hold of the situation??? Ugggg.....I know your MINI will be fixed as good as new soon.
Donna
even clearcoat only, i can tell it was repainted. perhaps
im too sensitive.
Hopefully you can get it righted, and then just laugh about it.
