DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Average Speed
Old Jun 22, 2007 | 05:16 AM
loxycoon's Avatar
loxycoon
Average Speed
So I have successfully managed to have the average speed on my MINI clock in at 1.3 mph. I wonder what this says about NoVA/DC traffic??
Actually, I am not sure, but I assume this is because of my bad habit of sitting at stop lights with my breaks off (my MINI is a manual), or with just the parking break on. Otherwise, my commute to work every morning would take me over 2 hours!
Old Jun 22, 2007 | 05:45 AM
Loony2N's Avatar
Loony2N
Although not a good habit, that should not affect your average speed. Of course, being stopped will. Around here, I usually average about 14 MPH, which is misleading, because it's either 0 or 50 - 60, most of the time.
Old Jun 22, 2007 | 06:12 AM
jsharra's Avatar
jsharra
I last reset mine around Christmas. Since then my average is about 47 mph.
Old Jun 22, 2007 | 09:02 AM
findude's Avatar
findude
Average speed is 26.2, the magic point where average fuel consumption and average speed converge. . . .
Old Jun 22, 2007 | 11:16 AM
Cruisin 06's Avatar
Cruisin 06
Because of the horrendous traffic here is st. louis my average speed is a whopping 4.7. very sad
Old Jun 22, 2007 | 12:06 PM
loxycoon's Avatar
loxycoon
My general thought is that average speed is calculated when the brakes are not on, but maybe this is incorrect. In that case, my bad habit of being stopped without the breaks on hasn't affected my average speed. It just must mean I sit at a lot of traffic lights since I really don't run into much traffic.
Still pretty intersting when you calculate in my long distance drives that average 65mph+. I guess my 2 1/2 mile commute to work (though with 7 stop lights) is really affecting it..
Old Jun 22, 2007 | 01:02 PM
Rowan's Avatar
Rowan
I thought mine was bad. What does it show you average mpg as?
Old Jun 22, 2007 | 03:36 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Nope, it uses running time as far as my experience. I have been sitting at a gas station recording my normal data for my logging and watched the average speed change by a tenth of a mph.
Old Jun 22, 2007 | 03:46 PM
Motor On's Avatar
Motor On
Over 30 hours if I was averaging that slow Two sounds about right though
excessive low readings like that usually stem from an OBC Glitch have you tried reseting?
Old Jun 24, 2007 | 07:43 AM
defylogik's Avatar
defylogik
29.5 mph. i very rarely ever get to go fast :(((((
Old Jun 24, 2007 | 05:20 PM
Rowan's Avatar
Rowan
Mine's around 27.5....damn DC driving.
Old Jun 26, 2007 | 08:16 AM
loxycoon's Avatar
loxycoon
No - how do I reset this? Wouldn't have anything to do with my funky clock, would it? Yes, I'm one of those that has some kind of bios error with my clock. It always runs extrememly fast.
Oh, and my average miles per gallon is 27.6. Much lower than it should be for a stick, but if I average 1.3 mph, I guess not so bad!
Old Jun 27, 2007 | 04:05 AM
DaCrema's Avatar
DaCrema
In the summer I sometimes get 27ish mpg (math on fill up agreed with the computer the 3-4 times I did it). Get the AC going in stop and go when one of the bridges out of town get clogged and the MPG numbers drop fast. And yes I too spend a lot of time in nutral at the stop lights with the hand brake on. If the cars all around you are not going any where no point in being in gear.
Old Jun 27, 2007 | 07:54 AM
moodylewdd's Avatar
moodylewdd
Mine is the 6 speed, and my average mpg is 30.5, and has been for quite sometime.
Old Jun 27, 2007 | 08:29 AM
delelie's Avatar
delelie
From: if home is where the heart is, then I must be in Amsterdam
Actually, it might. I had the same problem with my clock and mph read-out (clock ran about 5-10 minutes fast or just stopped working all together at times and MPH sat between 1-2 for several months). Both were fixed by the dealer and I was told these were "known" problems. Don't know if there's any kind of TSB on either issue though.
I haven't had any problems since they fixed them, so you should consider taking your MINI in.
Old Jun 27, 2007 | 08:30 AM
Rowan's Avatar
Rowan
Just hold down the button that you use to cycle through the functions for a few seconds when you are looking at whichever reading you want to reset (mpg or mph) and it will reset to zero.
Gremothra
Sep 9, 2015 08:42 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
Suspension Products
Sep 2, 2015 10:32 AM
