D Stock Video from 2006 Solo Nationals
Here is a side-by-side of Craig and I's fast runs on the East course Tuesday morning.
http://gwl.rmsolo.org/misc/Craig(L),%20Graeme(R)%20East%20Course%20HPT%202006-1.wmv
I'll eventually get around to doing a Wednesday side-by-side, I promise!
Graeme
Graeme
I'll eventually get around to doing a Wednesday side-by-side, I promise! Graeme
how did you do the side-by-side? technically speaking...
I use Adobe Premier. I assign each run to a separate track then synchronise them on the timeline. Now I select the clip I want and choose "Clip -> Motion". Once in the "motion" window, I can set a scaling factor and a position. I use 50% scaling and move the clip to the top left corner. Once that's done, I repeat with the other track and move it to the top right corner.
Simple huh?
Graeme
Simple huh?
Graeme
on
Graeme
Craig
Cool video. I assume that was in Topeka? A member of our Manitoba (Canada) club raced in FStock with his Mustang and came in 2nd at the event. LOTS of members in our club are thinking of going next year. I co-drive my MINI and we just can't seem to "figure it out". We played with tire pressures all year and still can't seem to get the right amount of bite in the front and swivel from the rear to capture FTD here.:impatient
We run DSP here.
Can you tell me what set up you have?
Tires:
Sway bars:
Springs:
Allignment:
We run DSP here.
Tires:
Sway bars:
Springs:
Allignment:
I don't think we had the camera rolling on day 2, I think our reasoning was that it was day 2 and any data at that point would be useless after the event. Anyway, without the video, I do know that I took WAY too wide of a line on my 1st 2 runs on the showcase sweeper, on the last run, I tightened up my line on the first 2/3 rds of the sweeper, then bumped it out a bit at the end before the left hand turn to carry the speed up the hill. Thats not as good as video though is it?
Craig
If you do happen to stumble onto them, that will be interesting to see if my feeling that I lost time in that sweeper were correct. I also felt that I really pushed the homecoming slalom on my last run as well, but, I did hit a cone so it didn't count.
Here is the video from the West course. Turns out I did get all 6 runs - phew!
Both our fastest clean runs were our 2nd runs. Craig - 52.311, Me - 52.285. Again, amazingly close.
Craig (L) vs Graeme (R) West course HPT 2006
Since Craig ran with #199, he had the luxury of knowing the Championship was sewn up when he got to the line for his last run. Here is his 3rd run vs his 2nd run where he let it all hang out.
Craig - 3rd run (L) vs 2nd run (R) West Course HPT 2006
Craig, if I'm interpreting this video correctly, you did not lose much time in the sweeper like you thought. You were however very tentative through both slaloms on your 2nd run but nailed them both on your 3rd. Pity about that pesky cone!!!
Graeme
Graeme
