New lifted blacked out countryman
Old 11-13-2015, 07:38 AM
ECSTuning is offline
Received 1,966 Likes on 1,766 Posts
Originally Posted by ncraig
Thanks! any Black Friday deals on spacers?
You will have to wait and see
  #52
Old 11-13-2015, 09:50 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Finally:(Big thanks to Chris!!!!!)
This looks wicked! Love the color too and the tint on the headlights.
888.280.7799 | 6am - 5pm PST
  #53
Old 11-13-2015, 11:07 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Normally I don't like lifted cars, but yours looks great!
  #54
Old 11-14-2015, 06:51 PM
ncraig's Avatar
ncraig
ncraig is offline
Thanks a lot for all the kind words
  #55
Old 02-19-2017, 01:04 AM
ROD-Z's Avatar
ROD-Z
ROD-Z is offline
Roof rack
Originally Posted by PelicanParts.com
This is pretty awesome. I like how it matches your truck. I like the basket on the roof look on the Countryman.
Hello,
May I ask what brand roof rack that is? Not the basket.
It's not the Mini brand because the horizontal bars extends past the vertical clamp post.
Thanks, Rodney
  #56
Old 02-19-2017, 01:12 AM
ROD-Z's Avatar
ROD-Z
ROD-Z is offline
Lifted or not?
Originally Posted by bmwr606
you say your tires are 205/70R16?
i run that size winter tire on my all4 with sport suspension (10 mm lower than standard suspension) using mini euro oem 16x6.5 et 46 alloys ... no rubbing at all
i would have guessed you could go larger on the tire? like 215/75R16?
Hello,
You are able to run 205/70R16 on a Countryman without being lifted?
Do you think the 215/70R16 TA's would fit on a non-lifted Countryman with rubbing?
Thanks, Rodney
  #57
Old 02-27-2017, 12:44 AM
ROD-Z's Avatar
ROD-Z
ROD-Z is offline
Large diameter tires
Hello,
Does anyone know what is the largest tire in diameter that can be run on a Countryman All4 without rubbing.
I have 17" wheels but looking to buy 16" wheels and run 215/70r16 big ta's.
Can I use this without the lift from cooper crap or M7?
I would probably put the lift on later; but I need to buy new tires now!
Thanks for for help.
Rodney
  #58
Old 02-27-2017, 07:22 AM
With the M7 Speed 2” kit Tire Max is 28.5". Above that ECS wheels spacers and trimming the wheels arches are needed. Dont know what the stock height can run( no lift kit), I imagine far less.
  #59
Old 03-17-2017, 02:31 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
rodney,
offset will be the final factor ... i have 16x6.5 et 46 wheels with 205/70R16 tires (27.3 inch OD) and have less than .25 inch clearance to suspension on the inner side of the tire
height wise 215/70R16 should fit no problem
  #60
Old 03-26-2017, 05:50 PM
jaskel's Avatar
jaskel
jaskel is offline
rodney,
do you have pics of your setup? Do the wheels bottom out in the fender at any point? I am lowered on hr springs ATM but just found out I will be moving to Alaska, and am rethinking the idea of the street look for up there, my not be as effective
  #61
Old 03-27-2017, 12:31 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
my 12 cms all4 has the factory sport suspension that sits 10 mm lower tham the standard suspension.
no rubbing anywhere ... at the tire store, we put 4 ea 200 pound people in the seats and 2 ea more sitting on the open boot edge ... the suspension was on the bump stops all 4 corners ... no rubbing at full lock both directions, no rubbing on wheel well liners ... 215/70R16s did rub the liners with the 1200 pounds of people aboard, just touched, standard suspension might clear
Attached Thumbnails New lifted blacked out countryman-100_1914-001.jpg.jpeg   New lifted blacked out countryman-100_1910-001.jpg   New lifted blacked out countryman-100_1918.jpg   New lifted blacked out countryman-100_1922.jpg   New lifted blacked out countryman-100_1920.jpg
  #62
Old 10-21-2017, 05:21 PM
Old_Man_R60's Avatar
Old_Man_R60
Old_Man_R60 is offline
its Moda MD20 front tirerack, 215/70/r16, offset is 40
Love the look and the fit! If I may ask, was the 40 offset in the wheels? Or was the 40 offset a combination of wheel position & spacers?
dyeLucky
09-11-2015 10:41 AM
SunnySideUp
R57 :: Cabrio Talk (2009+)
08-26-2015 01:16 PM
08-13-2015 12:57 PM
08-07-2015 08:02 AM
dyeLucky
08-07-2015 07:10 AM
Quick Reply: New lifted blacked out countryman
