CM wheel center cap question
Old May 7, 2012 | 02:16 PM
MotoGreg's Avatar
MotoGreg
MINI changed the wheels on the CM to BMW specs, with a 5x120 bolt pattern, and the 72.56mm hub bore. Does anyone know if they changed the center cap to the larger BMW size (approx 68mm) as well? Or do they still use the same center caps as the small Coopers (approx. 54mm I believe)?
I just got some wheels that accept BMW center caps for the CM... except we won't have the car for another week. I'm trying to figure out if the stock CM caps are going to fit these BMW spec wheels, or if I'll have to figure out a plan B. Thanks in advance for any help.
Old May 7, 2012 | 04:14 PM
chrunck's Avatar
chrunck
Pretty sure they're the same size. I'll go measure since I'm so nice
I measured it at 2 inches, which should be ~50mm.
Old May 7, 2012 | 06:12 PM
DR61's Avatar
DR61
My standard CM wheel's center cap is 55 mm outside diameter.
Old May 7, 2012 | 07:41 PM
MotoGreg's Avatar
MotoGreg
Ok, thanks guys. So it looks like it's probably the same as all the other MINIs then.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
